Cut rules
- snowgoer540
- Thank you received: 907
From my understanding:[I'm still a bit fuzzy on the difference between synchronized with motion, and immediately.
Synchronised means motion continues on it merry way and when the next G1/2/3 move after the M62/62 is reached it will enact that code.
Immediate means motion moves along then stops, the M64/65 is enacted then motion start again
This is the percentage of the cut feed rate of the current material.EDIT: Also, one question about the VAD percentage, so it considers 100% feed rate the feed rate with no M67 applied? As opposed to 100% being when it reaches the commanded 60% of the material's feed rate... if that makes sense?
I think that makes perfect sense. Thank you
- CBEAR
- Thank you received: 46
- phillc54
- Thank you received: 2100
There are some cut rules in with this postprocessor.Thank you for all of the responses. I was using the 64 & 65 as I was unsure what synchronized with motion meant when I originally set up the cut rules. As far as the vad, that clears it up a lot for me. Thank you! I thought that it would go off of the programmed velocity and was thinking for example that I wanted a 250ipm speed to slow down to 80% in a corner that it would slow down to 200ipm and the thc wouldn't be disabled causing the torch to dive because it was technically supposed to run at 200iom. But since you say that it judges it off of the material speed, that makes a lot more sense. Thank you.
forum.linuxcnc.org/plasmac/38438-plasmac-post-processors#158270
You do need to be careful with sync and immediate. For instance you do need a G0/1/2/3 after a sync to make it happen. If you are say near the end of the file and there was no more motion then you would use immediate.
Edit: you can mix and match, so you could do a sync turn on and an immediate turn off.
- CBEAR
- Thank you received: 4154
You were correct, the m62 and m63 worked well, and did not interrupt fluid motion. The plasmac post doesn't appear to be able to see velocity slow down path rules at the moment. These are really important for a few different reasons, but it all pretty much boils down to allowing the arc to catch up at some key spots throughout a cut.
Can you share some snippets of the generated gcode? The machine's acceleration has a big impact on some of this stuff.
- phillc54
Could you post a rule that doesn't work.The plasmac post doesn't appear to be able to see velocity slow down path rules at the moment.
- CBEAR
- phillc54
linuxcnc.org/docs/2.8/html/gcode/m-code.html
- CBEAR
- phillc54
