Recent PlasmaC Update and No Motion
6 years 2 months ago #179499 by Tesremos
well.. that sounds like a problem!
6 years 2 months ago #179500 by phillc54
It should kook sometong like this:
Warning: Spoiler!
There is also a test and a wizards directory missing.
Can you check and let me know.
6 years 2 months ago #179501 by phillc54
Can you try it with Use Auto Volts checked.
6 years 2 months ago #179502 by Tesremos
had tried autovolts. no auto volts.
auto volts resulted in no movement after pierce.
set volts resulted in no movement after pierce.
thc disabled resulted in no movement after pierce.
a quick one. the low pass filter. the number specified there is how many samples are taken of the voltage per second yes?
trouble shooting being made harder, im in australia. and the machine is in indiana.
i cant attest to where the two missing directories, or all the *links to plasmac core files are.
possibly due to config being copied to usb to be uploaded via windows pc.
6 years 2 months ago #179503 by phillc54
lowpass filter number is the cutoff frequency, you have set to 2Hz.
I can emulate the issue here on my sim. The first cut goes ok but then after that there is no motion.
The following user(s) said Thank You: Tesremos
6 years 2 months ago - 6 years 2 months ago #179507 by phillc54
You should have the [JOINT_3]HOME near the top of travel. I set it to 2.9 and it worked flawlessly, you have it at 1.0 which is below the probe height.
Having said that it should still work so I will have a look to see what needs changing. In the meantime set it to 2.9 and give it a try.
[strike]There are other minor errors in the ini file. I will note them down and post them tomorrow.[/strike]
Edit: here they are...
Warning: Spoiler!
Last edit: 6 years 2 months ago by phillc54.
