Recent PlasmaC Update and No Motion
6 years 2 months ago #179631 by phillc54
snowgoer540 wrote:
phillc54 wrote: Should affect both
So what was broke exactly? I had some weird issues that sounded similar at first but I attributed them to the hypersensing comp that Rod ended up updating. I guess I’m asking What recreated the issue?
load say the imperial wrench, start a cut (leave the torch disabled) do a breakaway then resume the job. Motion doesn't resume after the probe.
6 years 2 months ago #179632 by Tesremos
will we see a v0.166 in the config tab once the update is successfully installed?
6 years 2 months ago #179634 by phillc54
Yes. The Buidlbot hasn't yet started to build the packages so it may be a while.
6 years 2 months ago #179637 by snowgoer540
You know, you’d think I would have experienced this when I was doing the thc tuning and I had my float switch clamped. Maybe I did and I chalked it up to other stuff, because I was fixated on tuning. I wasn’t running a program though just single cuts.
Guess I need to break my torch away more often haha.
6 years 2 months ago #179638 by Tesremos
After applying update via halcompile.
testing with imperial wrench, machine failed to probe (no ohmic connection) and hit the breakaway, retracted to full height, even with program stopped "no programming running" i have no jog, AXIS +/- does nothing, keyboard does nothing, pressing start moves to line 10 of the gcode, and stops.
6 years 2 months ago #179639 by phillc54
snowgoer540 wrote: You know, you’d think I would have experienced this when I was doing the thc tuning and I had my float switch clamped. Maybe I did and I chalked it up to other stuff, because I was fixated on tuning. I wasn’t running a program though just single cuts.
Yes, I am surprised that it hasen't reared is ugly head before.
The main issue is that is wasn't waiting for the offset to complete when going to max height. I also reduced the max offset height to 5mm (0.197") below max limit so we stay well away from the issue with offsets and limits.
Time to create page: 0.199 seconds
