Recent PlasmaC Update and No Motion
- phillc54
- Thank you received: 2100
27 Aug 2020 05:25 - 27 Aug 2020 05:50 #179656
by phillc54
Replied by phillc54 on topic Recent PlasmaC Update and No Motion
PlasmaC has nothing to do with trivkins, I don't know what that would be about.
Could you post your compressed config directory.
Edit:
Just to make sure we are on the same page I installed 2.9 from the Buildbot then installed the new plasmac.comp, edited plasmac.tcl as per the earlier post and I cannot get it to fault, it appears to do everything it should.
Edit:
Last edit: 27 Aug 2020 05:50 by phillc54.
The following user(s) said Thank You: Tesremos, PurduePete, snowgoer540
- PurduePete
- Thank you received: 10
28 Aug 2020 01:15 #179766
by PurduePete
Replied by PurduePete on topic Recent PlasmaC Update and No Motion
I am unable to get that line put in. I get an error on boot. See below. If I comment that line out then I can run the program but the z axis doesn't move from the home position. No probe function or any other.
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.0-pre0-2662-g3039a67a6
Machine configuration directory is '/home/forcedesigns/linuxcnc/configs/cnc_plasma'
Machine configuration file is 'cnc_plasma.ini'
INIFILE=/home/forcedesigns/linuxcnc/configs/cnc_plasma/cnc_plasma.ini
VERSION=1.1
PARAMETER_FILE=imperial_parameters.txt
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
COORDINATES=XYYZ
KINEMATICS=trivkins coordinates=XYYZ kinstype=BOTH
Starting LinuxCNC...
twopass:invoked with <> options
twopass:found ./cnc_plasma.hal
twopass:found ././plasmac/plasmac.tcl
twopass:found ./cnc_plasma_connections.hal
twopass: Error in file ./cnc_plasma_connections.hal:
Pin 'halui.machine.is-on' was already linked to signal 'machine-is-on'
trivkins: coordinates:XYYZ
Joint 0 ==> Axis X
Joint 1 ==> Axis Y
Joint 2 ==> Axis Y
Joint 3 ==> Axis Z
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:10:43:db
hm2_eth: discovered 7I76E-16
hm2/hm2_7i76e.0: Low Level init 0.15
hm2/hm2_7i76e.0: Smart Serial Firmware Version 43
Board hm2_7i76e.0.7i76.0.0 Hardware Mode 0 = standard
Board hm2_7i76e.0.7i76.0.0 Software Mode 0 = io_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 1 = io_ana_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv
hm2/hm2_7i76e.0: 51 I/O Pins used:
hm2/hm2_7i76e.0: IO Pin 000 (P1-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 001 (P1-14): StepGen #0, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 002 (P1-02): StepGen #1, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 003 (P1-15): StepGen #1, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 004 (P1-03): StepGen #2, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 005 (P1-16): StepGen #2, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 006 (P1-04): StepGen #3, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 007 (P1-17): StepGen #3, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 008 (P1-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 009 (P1-06): StepGen #4, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 010 (P1-07): Smart Serial Interface #0, pin tx0 (Output)
hm2/hm2_7i76e.0: IO Pin 011 (P1-08): Smart Serial Interface #0, pin rx0 (Input)
hm2/hm2_7i76e.0: IO Pin 012 (P1-09): IOPort
hm2/hm2_7i76e.0: IO Pin 013 (P1-10): IOPort
hm2/hm2_7i76e.0: IO Pin 014 (P1-11): IOPort
hm2/hm2_7i76e.0: IO Pin 015 (P1-12): IOPort
hm2/hm2_7i76e.0: IO Pin 016 (P1-13): Encoder #0, pin A (Input)
hm2/hm2_7i76e.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_7i76e.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_7i76e.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_7i76e.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_7i76e.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_7i76e.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_7i76e.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_7i76e.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_7i76e.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_7i76e.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_7i76e.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_7i76e.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_7i76e.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_7i76e.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_7i76e.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_7i76e.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_7i76e.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_7i76e.0: IO Pin 034 (P3-01): IOPort
hm2/hm2_7i76e.0: IO Pin 035 (P3-14): IOPort
hm2/hm2_7i76e.0: IO Pin 036 (P3-02): IOPort
hm2/hm2_7i76e.0: IO Pin 037 (P3-15): IOPort
hm2/hm2_7i76e.0: IO Pin 038 (P3-03): IOPort
hm2/hm2_7i76e.0: IO Pin 039 (P3-16): IOPort
hm2/hm2_7i76e.0: IO Pin 040 (P3-04): IOPort
hm2/hm2_7i76e.0: IO Pin 041 (P3-17): IOPort
hm2/hm2_7i76e.0: IO Pin 042 (P3-05): IOPort
hm2/hm2_7i76e.0: IO Pin 043 (P3-06): IOPort
hm2/hm2_7i76e.0: IO Pin 044 (P3-07): IOPort
hm2/hm2_7i76e.0: IO Pin 045 (P3-08): IOPort
hm2/hm2_7i76e.0: IO Pin 046 (P3-09): IOPort
hm2/hm2_7i76e.0: IO Pin 047 (P3-10): IOPort
hm2/hm2_7i76e.0: IO Pin 048 (P3-11): IOPort
hm2/hm2_7i76e.0: IO Pin 049 (P3-12): IOPort
hm2/hm2_7i76e.0: IO Pin 050 (P3-13): IOPort
hm2/hm2_7i76e.0: registered
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
2856
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
http://pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Thu 27 Aug 2020 09:13:08 PM EDT
UTC Date: Fri 28 Aug 2020 01:13:08 AM UTC
this program: /usr/bin/linuxcnc_info
uptime: 21:13:08 up 3:04, 1 user, load average: 0.90, 0.99, 0.65
lsb_release -sa: Debian Debian GNU/Linux 10 (buster) 10 buster
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/forcedesigns/linuxcnc/configs/cnc_plasma
USER: forcedesigns
LOGNAME: forcedesigns
HOME: /home/forcedesigns
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1280x1024 pixels (338x270 millimeters)
PATH: /usr/bin:/home/forcedesigns/linuxcnc/configs/cnc_plasma/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: forcedesigns
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT RT Debian 4.19.132-1 (2020-07-24)
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.19.0-10-rt-amd64 root=UUID=3a2455eb-0f3b-4244-9f41-d79cad5e032f ro quiet
model name: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
cores: 2
cpu MHz: 2567.106
parport:
serial: 0000-0000 : serial 0000-0000 : serial
Versions:
gcc: gcc (Debian 8.3.0-6) 8.3.0
python: Python 2.7.16
git: git version 2.20.1
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.9.0-pre0-2662-g3039a67a6
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
PYTHON: /usr/bin/python2.7
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un linuxcnc <none> <none> (no description available)
un linuxcnc-dev <none> <none> (no description available)
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-en 1:2.9.0~pre0.2638.gadd5f0b68 all motion controller for CNC machines and robots (English documentation)
un linuxcnc-sim <none> <none> (no description available)
un linuxcnc-sim-dev <none> <none> (no description available)
ii linuxcnc-uspace 1:2.9.0~pre0.2662.g3039a67a6 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.9.0~pre0.2662.g3039a67a6 amd64 PC based motion controller for real-time Linux
- Tesremos
28 Aug 2020 01:31 #179771
by Tesremos
Replied by Tesremos on topic Recent PlasmaC Update and No Motion
i get this error when i try and run an actual.machine. and not a sim.
im unable to test on my machine other then simulations for now. i should be up and running for testing tommorrow.
- phillc54
28 Aug 2020 02:01 - 28 Aug 2020 03:25 #179776
by phillc54
The error message is telling you that the pin halui.machine.is-on is being used elsewhere.
The new PlasmaC.comp uses this pin to clear offsets.
You need to find where else it is being used and change that Hal file to suit.
Edit: comment out line 291 in cnc_plasma.hal
net machine-is-on halui.machine.is-on
Last edit: 28 Aug 2020 03:25 by phillc54.
- PurduePete
28 Aug 2020 07:08 - 28 Aug 2020 07:09 #179790
by PurduePete
Got that corrected now. It runs a full program! Woohoo. Unfortunately it only will run 1 full program for every total restart of the computer. Odd but it's letting me limp by and get this job done.
It does the same thing where it will retract to home after the job is complete and then not move any further with no jog control. I also still get nan every once in a while and have to restart linuxcnc until it goes away.
Last edit: 28 Aug 2020 07:09 by PurduePete.
- phillc54
28 Aug 2020 07:16 - 28 Aug 2020 07:31 #179791
by phillc54
Can you explain what is happening or not happening, I can run one gcode file several times and can load a new program and run that. I am using the config you posted last.
Any error messages in the terminal?
Edit: you need to switch to manual mode to jog.
Edit2: In cnc_plasma_connections.hal try commenting out this line:
setp plasmac.lowpass-frequency 2
Last edit: 28 Aug 2020 07:31 by phillc54.
- Tesremos
28 Aug 2020 08:33 #179794
by Tesremos
Purduepete's current configuration attached. lowpass is set to 50, debounce is 5,
how do i run his specific config as is, as a simulation? so i can poke and prod to see if i can get it to misbehave?
i was going to configure my 7i76e to match his setup 100% and try that to simulate his problem. (seems overkill but im half way to assembled)
- PurduePete
28 Aug 2020 18:30 - 28 Aug 2020 18:48 #179865
by PurduePete
Phillc54, I actually thought it was all good. If I run a program it runs fine with the torch off. No issues. If stopped in the middle there are no problems. If it completes no issues starting another. But when a cut program is run with the torch on only that program will complete. Runs great the whole time for the most part, I'll circle back to this, but after that program it will only do the first cut and then will do what it has been doing not moving after pierce.
I did have an issue running some 3/16 plate. Was trying a few different things and bumped my lowpass to 50 from 2 and debounce to 5 from 50. Because the THC was a lot more responsive it dove at the end cut when it hit a pierce. After it did it 3 or 4 times it retracted to its safe height and would not allow jog or anything after killing the cut program. Required a computer reboot as well.
Last edit: 28 Aug 2020 18:48 by PurduePete.
- phillc54
29 Aug 2020 00:18 #179892
by phillc54
Use the attached simplified hal file instead of cnc_plasma.hal
<machine-name>_connections.ini file:
comment out all [JOINT_n] lines begining with HOME_SEARCH_VEL, HOME_LATCH_VEL & HOME_FINAL_VEL
uncomment everthing in the ini file [APPLICATIONS] section
add APP = halshow my.halshow to the [APPLICATIONS] section if I need to watch any pins
<machine-name>_connections.hal file, comment out all lines except:
loadrt debounce cfg=3
setp debounce.0.delay 5
addf debounce.0 servo-thread
setp plasmac.lowpass-frequency 0
net plasmac:axis-position joint.3.pos-fb => plasmac.axis-z-position
setp plasmac.multi-tool 0Please Log in or Create an account to join the conversation.
- phillc54
29 Aug 2020 00:29 #179893
by phillc54
Why are you changing the debounce value and the lowpass value. Are you taking Halscope readings that show this is required. Everyone I know uses the default values of lowpass = 0 and debounce = 5 which work well unless you have some electrical noise. A frequency of 2Hz seems a very odd number for lowpass and a debounce of 50 seems quite high. I am thinking that maybe you have electrical noise issues that you need to find. This may also have a bearing on the NaN reading that you occasionally get, I have not heard of that on any config I know about.Phillc54, I actually thought it was all good. If I run a program it runs fine with the torch off. No issues. If stopped in the middle there are no problems. If it completes no issues starting another. But when a cut program is run with the torch on only that program will complete. Runs great the whole time for the most part, I'll circle back to this, but after that program it will only do the first cut and then will do what it has been doing not moving after pierce.
Time to create page: 0.211 seconds
