Recent PlasmaC Update and No Motion
27 Aug 2020 02:29 #179625 by phillc54
Replied by phillc54 on topic Recent PlasmaC Update and No Motion
Should affect both
27 Aug 2020 02:35 #179627 by snowgoer540
Replied by snowgoer540 on topic Recent PlasmaC Update and No Motion
Should affect both
So what was broke exactly? I had some weird issues that sounded similar at first but I attributed them to the hypersensing comp that Rod ended up updating. I guess I’m asking What recreated the issue?
27 Aug 2020 02:49 #179631 by phillc54
Should affect both
load say the imperial wrench, start a cut (leave the torch disabled) do a breakaway then resume the job. Motion doesn't resume after the probe.
27 Aug 2020 02:50 #179632 by Tesremos
Replied by Tesremos on topic Recent PlasmaC Update and No Motion
will we see a v0.166 in the config tab once the update is successfully installed?
27 Aug 2020 03:02 #179634 by phillc54
Yes. The Buidlbot hasn't yet started to build the packages so it may be a while.
27 Aug 2020 03:14 #179637 by snowgoer540
Should affect both
You know, you’d think I would have experienced this when I was doing the thc tuning and I had my float switch clamped. Maybe I did and I chalked it up to other stuff, because I was fixated on tuning. I wasn’t running a program though just single cuts.
Guess I need to break my torch away more often haha.
27 Aug 2020 03:20 #179638 by Tesremos
After applying update via halcompile.
testing with imperial wrench, machine failed to probe (no ohmic connection) and hit the breakaway, retracted to full height, even with program stopped "no programming running" i have no jog, AXIS +/- does nothing, keyboard does nothing, pressing start moves to line 10 of the gcode, and stops.
27 Aug 2020 03:21 #179639 by phillc54
Yes, I am surprised that it hasen't reared is ugly head before.
The main issue is that is wasn't waiting for the offset to complete when going to max height. I also reduced the max offset height to 5mm (0.197") below max limit so we stay well away from the issue with offsets and limits.
  • PurduePete
  • PurduePete's Avatar Topic Author
  • Senior Member
  • Senior Member
27 Aug 2020 03:24 #179640 by PurduePete
Replied by PurduePete on topic Recent PlasmaC Update and No Motion
I have the same issues as Tesremos. I was able to dry run fine on the first program. But after that first dry run was complete and the program restarted, the second pierce caused the same issue and added a new one. I no longer have any job control after killing the cut program. Navigating to other screens is possible but nothing functions. Only fix is restarting LinuxCNC.
27 Aug 2020 03:24 #179641 by snowgoer540
So if I’m understanding correctly, how we have probe height offsets set could affect whether or not we saw an issue?
Time to create page: 0.162 seconds
