Recent PlasmaC Update and No Motion
- phillc54
- Thank you received: 2100
04 Nov 2020 21:53 #188345
by phillc54
Replied by phillc54 on topic Recent PlasmaC Update and No Motion
You may be better off starting a new thread in the stepconf section of the forum, a lot of folk probably won't notice your issues because this is in the plasmac section: forum.linuxcnc.org/16-stepconf-wizard
I think you should start a new configuration because you need to get these issues sorted out before add the plasmac configuration to your config.
- ajsinfotech
11 Nov 2020 16:58 - 11 Nov 2020 17:00 #189017
by ajsinfotech
Replied by ajsinfotech on topic Recent PlasmaC Update and No Motion
Hi team,
I have the same issue:
I'm using gmoccapy in a milling machine (no plasma cutter).
I'm totally stuck with this since many days. There's no info about it.
The only info I got surfing the web was:
emc.hh File Reference
I can't figure it out what is happening.
Any idea?
command (EMC_SPINDLE_OFF) cannot be executed until the machine is out of E-stop and turned on
Any idea?
Last edit: 11 Nov 2020 17:00 by ajsinfotech.
Time to create page: 0.215 seconds
