Recent PlasmaC Update and No Motion
- Thank you received: 4154
29 Aug 2020 20:49 #179966
Replied by rodw on topic Recent PlasmaC Update and No Motion
So how are you doing probing? Still with Ohmic3 or the float switch?
If Ohmic, Is it a water table? is the plate wet on the second probe?
Is the torch lifting to pierce height after probing?
If something goes wrong on a probe event and the Ohmic probe output does not turn on, it won't ever proceed to a cut. This is more likely with ohmic3 as you may need to change the settings based on different water quality etc.
I guess what I am trying to understand if the issue is my ohmic3 component, an ArcOK failure or something in Plasmac.
Regarding the Z axis settings, I found a lot of problems went away if I jogged to the top of travel and touched off at that height. eg. if I had 4" of z axis travel, touch off and enter 4.0" when touching off.
- Tesremos
- Thank you received: 10
29 Aug 2020 21:02 #179969
by Tesremos
Replied by Tesremos on topic Recent PlasmaC Update and No Motion
process used to update orignally that started this rollercoaster.
sudo apt update
sudo apt get-update
sudo apt-get dist-upgrade
downloaded ohmic3.comp
sudo apt-get install linuxcnc-uspace-dev
compiled ohmic3.
noted that plasmac version still read 0.142?( i could look this number up if vital)
ran configurator in upgrade mode.
at this stage, it was doing the fail to move after pierce.
made a 100/ new config fron scratch, which got homing working correctly.
applied confurator to it.
did not add any ohmic to it.
still.issue. came to the board, applied your plasmac.comp each time you loaded it.
yesterday we tried a full linuxcnc purge.
sudo rm modules (to ensure no extra reminants were left hanging)
re installed 2.9 tried again.
purged 2.9
rolled back to 2.8 tried again.
here we are now at today
sudo apt update
sudo apt get-update
compiled ohmic3.
purged 2.9
- Tesremos
29 Aug 2020 21:04 #179970
by Tesremos
ohmic is disabled enitrely until we get standard float switch cutting operational.
ohmic3.comp / .so has been purged
29 Aug 2020 21:11 #179971
Ok, so not my software
So does the torch probe with float switch and rise to pierce height? If yes all probing is OK.
Next step, does the torch fire at all?
If no, sounds like a plasmac issue or faulty wiring.
Use halshow to check that the output pin is being triggered. Confirm with a multimeter.
If the output is not being enabled it is a plasmac issue..
- Tesremos
29 Aug 2020 21:58 #179972
by Tesremos
moves to probe location
probes down,
uses float switch
finds material,
moves to pierce height
pierces.(torch works fine)
moves to cut height (torch still on)
ceases movement.
arc_okay is lost,
retracts to "pause position"
and controls are dead.
no resume. no jog. no start. no reloading.
stop button works. but jog machine will not move until restarted
(hopefully my thcad from stuart arrives this week and i can play with hypersensing ((excited)) )
probes down,
uses float switch
finds material,
ceases movement.
arc_okay is lost,
- Thank you received: 7501
29 Aug 2020 22:11 #179974
Having the same issue with 165 and 169, so started from terminal and got a message saying keyboard interruption so i changed the laptop, the issue remained but the keyboard error did not appear ever again, no errors appear, period.
I chalked it to an interference issue from the plasma having a 12 meter long cable going parallel to the rest of the machine cables, although they are shielded, they are not of good quality to write home about.
But the original poster mentions this happens with the torch off, so i am baffled as it never happened here in over a moth of every day dry runs lasting 10 to 12 hours a day, with every version of PlasmaC up to 148.
Replied by tommylight on topic Recent PlasmaC Update and No Motion
No need to restart, just disable and enable with F2 will bring motion back and can continue to cut.moves to probe location
probes down,
uses float switch
finds material,
ceases movement.
arc_okay is lost,
- Tesremos
29 Aug 2020 22:27 #179978
by Tesremos
reckon we can roll back to pre 0.148 and try?
29 Aug 2020 22:30 #179980
Then again i have to go do a photo shooting session there in a few days, so if i have the time i can give it a run.
You can try, but i can not as the machine is 120KM from me.reckon we can roll back to pre 0.148 and try?
29 Aug 2020 22:57 #179982
What movie star now Tommy? An hour ago you were starting battles! (on another thread)
So anyway back on topic.
Normally, the only buttons enabled when the cut pauses is the resume or cancel button. You cannot jog while paused!
So possibly, the machine lost ArcOK (or did not establish an arc) and perhaps Plasmac does not recover cleanly. Lets focus on the loss of AcOK now.
Did it really happen? (Lose ArcOK) or did Plasmac imagine it?.
1. Does your machine have an ArcOK output?
2. Are you using it?
3. What material and thickness?
4. What is your pierce delay? (if too long, the material will burn away and maybe loos a valid arc.)
- phillc54
- Thank you received: 2100
30 Aug 2020 00:50 - 30 Aug 2020 01:33 #179988
by phillc54
Replied by phillc54 on topic Recent PlasmaC Update and No Motion
@PurduePete
Did you try my earlier suggestion of changing the limit values. I have just completed some more testing an it seems to work ok by either changing the Probe Height to 4.0 or the Safe Height to 1.0 without changing anything in the ini file.
It sure is strange though...
Edit: I am slowly working my way though versions to find where I broke it...
Last edit: 30 Aug 2020 01:33 by phillc54.
Time to create page: 0.793 seconds
