Recent PlasmaC Update and No Motion
- Jean NT76
27 Oct 2020 21:06 #187469
by Jean NT76
Replied by Jean NT76 on topic Recent PlasmaC Update and No Motion
I have run the test mode on the Proma, in the test mode and on the board (by bridging the pins) only the arcOK signal is working in the GUI. The up and down light in the GUI never lights up. Thus I thought there must be a mistake with the definition of the up and down variables.
- Thank you received: 7501
27 Oct 2020 21:19 #187472
Replied by tommylight on topic Recent PlasmaC Update and No Motion
Did you read my previous post ?
Follow it in detail, that is the only way to check the UP/Down function without starting the torch....
Well there is another way, by using the "show hal configuration" from the "machine" menu and watching the parallel port input pins.
- Jean NT76
28 Oct 2020 11:54 #187551
by Jean NT76
As I needed the Inputs for ArcOK, Up and Down, I had to use one single Input for all limits and home.
This homing doesn't work. The machine trigers the limit switch without reacting. It simply pass over it and continue moving.
28 Oct 2020 19:26 #187609
linuxcnc.org/docs/2.8/html/config/ini-homing.html
look or shared homing or home is shared
- Jean NT76
28 Oct 2020 20:19 #187618
by Jean NT76
Hello "Tommylight"
The linked document I already read 3 times and I don't get something out.
Unfortunately I do not understand your message, in my original post I shared the ini and hal file.
Or should I just add:
HOME_IS_SHARED = 1
and this in the ini for all 3 joints?
Sorry my IT skills are still limited.
I am grateful for all help.
Jean
HOME_IS_SHARED = 1
Jean
- Thank you received: 4154
28 Oct 2020 21:13 #187629
Replied by rodw on topic Recent PlasmaC Update and No Motion
You may also need to tell each joint to ignore limits when homing. (another setting)
- Jean NT76
30 Oct 2020 10:08 #187766
by Jean NT76
I have modified the ini file with the following:
[JOINT_0]
HOME_IS_SHARED = 1 #jb
#HOME_IGNORE_LIMITS = YES #jb
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -10.0
MAX_LIMIT = 1010.0
MAX_VELOCITY = 30.0
MAX_ACCELERATION = 100.0
STEPGEN_MAXACCEL = 125.0
SCALE = 100.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = -10.000000
HOME_SEARCH_VEL = -15.000000
HOME_LATCH_VEL = -5.000000
HOME_SEQUENCE = 1
With the HOME_IGNORE_LIMITS = YES LinuxCNC doesn't boot anymore. I get error messages about joints.
The HOME_IS_SHARED has not solve the issue. The Z axle run over the limit switch and crashed. The limit switch it self is working.
Any other idea how to approach this issue?
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -10.0
MAX_LIMIT = 1010.0
MAX_VELOCITY = 30.0
SCALE = 100.0
FERROR = 1
MIN_FERROR = .25
HOME_SEQUENCE = 1
- Thank you received: 2177
30 Oct 2020 13:57 #187793
Can you post those messages?
Replied by Aciera on topic Recent PlasmaC Update and No Motion
- Jean NT76
30 Oct 2020 14:58 - 30 Oct 2020 15:00 #187797
by Jean NT76
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0
Machine configuration directory is '/home/jango/linuxcnc/configs/burnithc'
Machine configuration file is 'burnithc.ini'
INIFILE=/home/jango/linuxcnc/configs/burnithc/burnithc.ini
VERSION=1.1
check_config: (trivkins kinematics) WARNING:
INCONSISTENT coordinates specifications:
trivkins coordinates=XYYZ
[TRAJ]COORDINATES=XYZ
PARAMETER_FILE=metric_parameters.txt
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYYZ
Starting LinuxCNC...
twopass:invoked with <> options
twopass:found ./burnithc.hal
twopass:found ././plasmac/plasmac.tcl
twopass:found ./burnithc_connections.hal
Starting DISPLAY program: axis
emcMotionInit: emcJointInit(0) failed
waiting for s.joints<0>, s.kinematics_type<0>
config string '0x378 out'
Debug file information:
Note: Using POSIX realtime
INIFILE: ERR_CONVERSION, section=JOINT_0, tag=HOME_IGNORE_LIMITS, num=1, lineNo=224
Unexpected realtime delay on task 0 with period 100000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
Waiting for component 'inihal' to become ready....note: MAXV max: 30.000 units/sec 1800.000 units/min
note: LJOG max: 30.000 units/sec 1800.000 units/min
note: LJOG default: 3.000 units/sec 180.000 units/min
.....INIFILE: ERR_CONVERSION, section=JOINT_0, tag=HOME_IGNORE_LIMITS, num=1, lineNo=224
..........INIFILE: ERR_CONVERSION, section=JOINT_0, tag=HOME_IGNORE_LIMITS, num=1, lineNo=224
...........INIFILE: ERR_CONVERSION, section=JOINT_0, tag=HOME_IGNORE_LIMITS, num=1, lineNo=224
.....A configuration error is preventing LinuxCNC from starting.
More information may be available when running from a terminal.
.1379
..1404
HAL: ERROR: exit called before init
<commandline>:0: waitpid failed milltask inihal
<commandline>:0: milltask exited without becoming ready
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Fr 30. Okt 15:56:54 CET 2020
UTC Date: Fr 30. Okt 14:56:54 UTC 2020
this program: /usr/bin/linuxcnc_info
uptime: 15:56:54 up 5 min, 1 user, load average: 2,17, 1,66, 0,81
lsb_release -sa: Debian Debian GNU/Linux 10 (buster) 10 buster
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/jango/linuxcnc/configs/burnithc
USER: jango
LOGNAME: jango
HOME: /home/jango
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1280x800 pixels (338x211 millimeters)
PATH: /usr/bin:/home/jango/linuxcnc/configs/burnithc/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: cnc28
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT RT Debian 4.19.146-1 (2020-09-17)
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.19.0-11-rt-amd64 root=UUID=e0835f07-816a-4dfb-92a9-1b31c6f34741 ro initrd=/install/initrd.gz quiet
model name: Intel(R) Core(TM)2 Duo CPU U7700 @ 1.33GHz
cores: 2
cpu MHz: 1064.012
parport: 0000-0000 : parport0 0000-0000 : parport0
serial: 0000-0000 : serial
Versions:
gcc: gcc (Debian 8.3.0-6) 8.3.0
python: Python 2.7.16
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: glade 3.22.1
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.8.0
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Gewünscht=Unbekannt/Installieren/R=Entfernen/P=Vollständig Löschen/Halten
| Status=Nicht/Installiert/Config/U=Entpackt/halb konFiguriert/
Halb installiert/Trigger erWartet/Trigger anhängig
|/ Fehler?=(kein)/R=Neuinstallation notwendig (Status, Fehler: GROSS=schlecht)
||/ Name Version Architektur Beschreibung
un linuxcnc <keine> <keine> (keine Beschreibung vorhanden)
un linuxcnc-dev <keine> <keine> (keine Beschreibung vorhanden)
un linuxcnc-doc <keine> <keine> (keine Beschreibung vorhanden)
ii linuxcnc-doc-cn 1:2.8.0 all motion controller for CNC machines and robots (Chinese
ii linuxcnc-doc-en 1:2.8.0 all motion controller for CNC machines and robots (English documentation)
ii linuxcnc-doc-es 1:2.8.0 all controlador de movimiento para máquinas CNC y robots (Español).
ii linuxcnc-doc-fr 1:2.8.0 all motion controller for CNC machines and robots (French documentation)
un linuxcnc-sim <keine> <keine> (keine Beschreibung vorhanden)
un linuxcnc-sim-dev <keine> <keine> (keine Beschreibung vorhanden)
ii linuxcnc-uspace 1:2.8.0 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.8.0 amd64 PC based motion controller for real-time Linux
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0
VERSION=1.1
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z
.1379
..1404
pastebin.com
USER: jango
LOGNAME: jango
HOME: /home/jango
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
uname items:
nodename -n: cnc28
machine -m: x86_64
/proc items:
cores: 2
cpu MHz: 1064.012
Versions:
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: glade 3.22.1
linuxcnc_var all:
RTS: uspace
Last edit: 30 Oct 2020 15:00 by Jean NT76.
- dgarrett
- Thank you received: 297
30 Oct 2020 15:33 - 30 Oct 2020 15:34 #187798
by dgarrett
Replied by dgarrett on topic Recent PlasmaC Update and No Motion
Note when commenting ini files (in 2.8):
Ref: linuxcnc.org/docs/2.8/html/getting-start...cter_ini_file_syntax
This likely leads to messages like:
(While the "YES" value is not exactly numeric,
HOME_IGNORE_LIMITS expects a boolean and
values "TRUE","YES","1" are accepted)
3.10. Stricter INI file syntax
Lines with numeric INI variables are no longer allowed
to have trailing text. In earlier versions of LinuxCNC
any text after the number was silently ignored, but as
of this version such text is totally disallowed. This
includes hash characters ("#"), which in this position
are a part of the value, not a comment
character.Ref: linuxcnc.org/docs/2.8/html/getting-start...cter_ini_file_syntax
INIFILE: ERR_CONVERSION, section=JOINT_0,tag=HOME_IGNORE_LIMITS, num=1, lineNo=224(While the "YES" value is not exactly numeric,
Last edit: 30 Oct 2020 15:34 by dgarrett.
Time to create page: 0.598 seconds
