Recent PlasmaC Update and No Motion
5 years 11 months ago #188306 by Jean NT76
Thank you very much.
How do you do the homing without limit switches?
The jog buttons aren't working. Linuxcnc want the homing first.
Testing in the stepconf does not work properly. Y has two motors and cannot be tested. The X doesn't work and Z works properly down and strangely (slip stick) up.
When I am in Linuxcnc and activate one of the limit switches, I get the error message that the a limit switch was hit. Thus I think they must work and are correctly defined with right pin.
5 years 11 months ago - 5 years 11 months ago #188323 by Jean NT76
I have checked now the cabling and found a broken cable.
But now the homing doesn't move the axis anymore, only the value of Z is increasing without movement.
I find it also strange that I cannot manipulate the motors with stepconf. And since the upgrade on linuxcnc 2.8 with debian my latency when up from under 20 000 to over 800 000. (I am using a Dell Latitude D430 with 2GB Ram.)
Last edit: 5 years 11 months ago by Jean NT76.
5 years 11 months ago #188345 by phillc54
You may be better off starting a new thread in the stepconf section of the forum, a lot of folk probably won't notice your issues because this is in the plasmac section: forum.linuxcnc.org/16-stepconf-wizard
I think you should start a new configuration because you need to get these issues sorted out before add the plasmac configuration to your config.
5 years 11 months ago - 5 years 11 months ago #189017 by ajsinfotech
Hi team,
I have the same issue:
command (EMC_SPINDLE_OFF) cannot be executed until the machine is out of E-stop and turned on
I'm using gmoccapy in a milling machine (no plasma cutter).
I'm totally stuck with this since many days. There's no info about it.
The only info I got surfing the web was:
emc.hh File Reference
I can't figure it out what is happening.
Any idea?
Last edit: 5 years 11 months ago by ajsinfotech.
Time to create page: 0.318 seconds
