- Thank you received: 2100
Well if your breakaway doesn't cater for this and this "issue" concerns you then to will need to find you own solution.rodw wrote: what happens if you probe on an edge that is hanging over a slat? Does it still break away?
You can't use stall detection with a stepper motor on the Z axis which is the general use case.
In any case break away when stationary with forces only in the x axis direction is not an expected use case for a breakaway.
Maybe you could start another thread.
I had no table on both machines !rodw wrote:
tommylight wrote:
Same here, no issue there.phillc54 wrote:
On my machine it hits the bottom limit, pauses, goes to maximum height and displays a bottom limit reached error.rodw wrote: I have described this issue many times. I do not know my current version. I think if the float switch is not working and ohmic fails, it goes into an endless probing loop. It may well have been fixed.
How can you hit the bottom limit when there is material on the table?
