- Thank you received: 2100
The latest update should fix that Tom. It is still being built by the Buildbot.tommylight wrote: 1.5s, it would stay lit in one place for nearly 30 seconds
tommylight wrote:
Same here, no issue there.phillc54 wrote:
On my machine it hits the bottom limit, pauses, goes to maximum height and displays a bottom limit reached error.rodw wrote: I have described this issue many times. I do not know my current version. I think if the float switch is not working and ohmic fails, it goes into an endless probing loop. It may well have been fixed.
Well if there is material under the torch then it will breakaway and the same result.rodw wrote: How can you hit the bottom limit when there is material on the table?
My torch breaks away with 1.6mm sheet which is the thinnest I cut.rodw wrote:
Thats an assumption and does not happen in the real world. Certainly not on my table.
On 2 mm plate, the material can bend down and also float travel can cope with a few mm.
