- Thank you received: 10
Tesremos wrote: Purduepete's current configuration attached. lowpass is set to 50, debounce is 5,
how do i run his specific config as is, as a simulation? so i can poke and prod to see if i can get it to misbehave?
i was going to configure my 7i76e to match his setup 100% and try that to simulate his problem. (seems overkill but im half way to assembled)
Why are you changing the debounce value and the lowpass value. Are you taking Halscope readings that show this is required. Everyone I know uses the default values of lowpass = 0 and debounce = 5 which work well unless you have some electrical noise. A frequency of 2Hz seems a very odd number for lowpass and a debounce of 50 seems quite high. I am thinking that maybe you have electrical noise issues that you need to find. This may also have a bearing on the NaN reading that you occasionally get, I have not heard of that on any config I know about.PurduePete wrote: Phillc54, I actually thought it was all good. If I run a program it runs fine with the torch off. No issues. If stopped in the middle there are no problems. If it completes no issues starting another. But when a cut program is run with the torch on only that program will complete. Runs great the whole time for the most part, I'll circle back to this, but after that program it will only do the first cut and then will do what it has been doing not moving after pierce.
I did have an issue running some 3/16 plate. Was trying a few different things and bumped my lowpass to 50 from 2 and debounce to 5 from 50. Because the THC was a lot more responsive it dove at the end cut when it hit a pierce. After it did it 3 or 4 times it retracted to its safe height and would not allow jog or anything after killing the cut program. Required a computer reboot as well.
