Recent PlasmaC Update and No Motion
6 years 2 months ago - 6 years 2 months ago #179648 by phillc54
Could you give this one a try.
Edit: after a machine off and on you will need to jog Z to a reasonable position
Last edit: 6 years 2 months ago by phillc54.
6 years 2 months ago #179649 by Tesremos
Okay, so motion continues very happily after both a breakaway trigger, or a machine disable, or estop.
but it does not attempt to probe at all. nor does breakaway stop the machine. it throws the error "break away switch activated program paused" 10-15 times , but does not pause.
6 years 2 months ago #179652 by phillc54
oops, I forgot to let you know to add this line:
net plasmac:machine-is-on halui.machine.is-on => plasmac.machine-is-on
It really belongs in /usr/share/doc/linuxcnc/examples/sample-configs/by_machine/plasmac/plasmac.tcl but you need to edit that as root. For this testing it should be ok in the connections.hal.
6 years 2 months ago #179653 by Tesremos
no change. added to net plasmac:machine-is-on halui.machine.is-on => plasmac.machine-is-on with to plasmac.tcl
6 years 2 months ago #179654 by phillc54
You did restart LinuxCNC?
6 years 2 months ago - 6 years 2 months ago #179655 by Tesremos
i restarted the entire pc just to be sure :)
Waiting for component 'trivkins' to become ready....Waited 3 seconds for master. giving up.
this is new?
Edit: working fine now! second restart + opening fresh plasmac sim seems to have worked.
Last edit: 6 years 2 months ago by Tesremos.
Time to create page: 0.173 seconds
