Custom user Button Touchoff in Axis
- snowgoer540
- Thank you received: 907
08 Sep 2020 06:23 #181245
by snowgoer540
I definitely want to learn. The end goal would be to learn python, keep gaining an understanding of what's going on under the hood, and at some point contribute in a more meaningful way. I do appreciate the guidance you gave me... just enough to prevent me from getting too frustrated and giving up, while making me bang my head against the wall so it sticks and I learn where to look for stuff. You should be a professor!
That said, I don't have to learn today. I worry about being a drain on your resources while learning/figuring this all out. So up to you, if you have the time to coach me through it, I'll definitely give it a go, and if you got a lot going on at the moment, no hard feelings. In this case, we both have the exact same working code, so either way it'll end up where it needs to go
Replied by snowgoer540 on topic Custom user Button Touchoff in Axis
You did well. If you want to do it the git way I can try to help you through.
The recent doc changes I made are below, pink are deletions and green are additions:
For the compressed backup:
github.com/LinuxCNC/linuxcnc/commit/9bb4...d5fdf0bb042ffa3ed7e1
For the final probe speed:
github.com/LinuxCNC/linuxcnc/commit/4dc4...d5fdf0bb042ffa3ed7e1
For the 2.8 release:
github.com/LinuxCNC/linuxcnc/commit/4db0...d5fdf0bb042ffa3ed7e1
Edit: these are the changes I ended up with.
- phillc54
- Thank you received: 2100
08 Sep 2020 07:22 #181265
by phillc54
Replied by phillc54 on topic Custom user Button Touchoff in Axis
I'll write up a few notes tomorrow. You will need a github account to get started.
docs.github.com/en/github/getting-starte...a-new-github-account
- snowgoer540
08 Sep 2020 07:47 #181275
by snowgoer540
I have one, I even did ... something ... in the Linux terminal to point my PC to my account.. though I'm not 100% sure I did it right.
Good deal!I'll write up a few notes tomorrow. You will need a github account to get started.
- snowgoer540
08 Sep 2020 19:12 #181345
by snowgoer540
All added to the doc I am editing. That should bring me to the latest I think? Please keep me apprised should anything else update.
The following user(s) said Thank You: phillc54, tommylight
- snowgoer540
12 Sep 2020 11:34 #181898
by snowgoer540
Just wanted to add that I added the following to the command to the works to park my torch 0.2 down from the top as recommended by Phill to prevent some of the offset issues I was having:
So the whole thing with the added code from previous posts becomes:
G53 G0 Z-0.2So the whole thing with the added code from previous posts becomes:
G10 L20 P0 X0 Y0 \ G53 G0 Z-0.2 \ %halcmd setp axisui.refresh 1
The following user(s) said Thank You: phillc54, EW_CNC
Time to create page: 0.493 seconds
