Linux Mint - PlasmaC upgrade confusion
- Mud
- Thank you received: 25
04 Sep 2020 07:35 #180673
by Mud
Linux Mint - PlasmaC upgrade confusion was created by Mud
I'm trying to upgrade PlasmaC and getting rather confused. So far I've updated LinuxCNC (sudo apt update / sudo apt dist-upgrade). I'm running Linux Mint 19.1, and trying to follow the instructions
here
. I have gotten to:
Running cat /etc/os-release in terminal I get:
So what should I be putting in the deb command in the repositories list to track PlasmaC updates? None of the buildbot packages look correct...is it Debian only? Don't underestimate my noobness here!
You can then either edit or delete existing LinuxCNC entries from the repositories list. You need to end up with the following set of stanzas as the only enabled references to LinuxCNC:
deb http://buildbot.linuxcnc.org/ <distro> <branch>-<type>
deb-src http://buildbot.linuxcnc.org/ <distro> <branch>-<type>Running cat /etc/os-release in terminal I get:
NAME="Linux Mint"
VERSION="19.1 (Tessa)"
ID=linuxmint
ID_LIKE=ubuntu
PRETTY_NAME="Linux Mint 19.1"
VERSION_ID="19.1"
HOME_URL="https://www.linuxmint.com/"
SUPPORT_URL="https://forums.ubuntu.com/"
BUG_REPORT_URL="http://linuxmint-troubleshooting-guide.readthedocs.io/en/latest/"
PRIVACY_POLICY_URL="https://www.linuxmint.com/"
VERSION_CODENAME=tessa
UBUNTU_CODENAME=bionicSo what should I be putting in the deb command in the repositories list to track PlasmaC updates? None of the buildbot packages look correct...is it Debian only? Don't underestimate my noobness here!
- Mud
04 Sep 2020 08:10 - 04 Sep 2020 08:43 #180678
by Mud
Replied by Mud on topic Linux Mint - PlasmaC upgrade confusion
Ah, finally found
this
thread, what's the recommendation? Can I just follow tommylight's instructions after the key server line?
edit: installing mint 19.3 since I'm messing around anyway...I'll just try to follow the instructions like a patient person...
Last edit: 04 Sep 2020 08:43 by Mud.
- Mud
04 Sep 2020 10:35 - 04 Sep 2020 10:56 #180690
by Mud
I think I've comprehensively broken the software, otherwise I don't know what to think. I was briefly on 2.9/master but after getting the attached communications problem (error finishing read, and also joint following problems) I rolled back to 2.8 for troubleshooting. It's still showing as PlasmaC v0.170 (which I'm not sure if it should on 2.8), but I also get the error on the non-PlasmaC config.
Pinging the 7i96 looks reasonable (~0.2-0.4ms). Should I just clean install Mint 19.2 using BeagleBrainz's ISO?
Edit: I timeshifted back to this morning (Mint 19.1 / LinuxCNC 2.8.0 / PlasmaC 0.139), and hopefully it stays stable. I shouldn't have had this little 'adventure' on a Friday!
Last edit: 04 Sep 2020 10:56 by Mud.
- Thank you received: 7506
04 Sep 2020 11:00 #180696
Replied by tommylight on topic Linux Mint - PlasmaC upgrade confusion
Change the kernel to 4.9, it has better latency.
The following user(s) said Thank You: Mud
- Mud
04 Sep 2020 11:47 #180708
by Mud
I've just tried 4.9 with the previous 19.3 / 2.8.0 and I still get communications-related errors (joint following error).
04 Sep 2020 11:57 #180710
Do you get one or the other, they are not the same thing.I still get communications-related errors (joint following error).
- Mud
04 Sep 2020 12:05 #180711
by Mud
The joint following error and the error finishing read. I am now thinking I was borderline before, and maybe the change of version has made it more apparent (to the point it errors even whilst doing nothing) - so consider it a possible red herring. I googled it and people were saying these both point back to communications with the 7i96.
To date I've cut a single circle, and come to think of it I may have had a joint error right at the end.
- Thank you received: 5337
04 Sep 2020 12:08 #180712
Replied by PCW on topic Linux Mint - PlasmaC upgrade confusion
What are the ping times to the 7I96?
What host hardware do you have?
Joint following errors and "error finishing read" errors point to Ethernet latency issues
- Mud
04 Sep 2020 12:12 #180713
by Mud
0.2-0.4ms pinging from the terminal. The PC is a Dell OptiPlex 980.
04 Sep 2020 12:19 - 04 Sep 2020 12:23 #180716
OK that's fairly terrible...
That PC uses a Intel MAC, have you disabled IRQ coalescing? That's a requirement
Also that PC supports Intel AMT, that also needs to be disabled in the BIOS
Last edit: 04 Sep 2020 12:23 by PCW.
Time to create page: 0.229 seconds
