Linux Mint - PlasmaC upgrade confusion
- Thank you received: 5337
06 Sep 2020 12:15 #181040
Replied by PCW on topic Linux Mint - PlasmaC upgrade confusion
I suspect something you have done has improved the Ethernet latency enough that 1 MS is OK.
I also think that it mighty be difficult to eliminate following errors because of the mode
switching on the Z axis so widening the limits to say 1 mm would be a reasonable
solution
solution
- Mud
- Thank you received: 25
06 Sep 2020 12:20 #181041
by Mud
Replied by Mud on topic Linux Mint - PlasmaC upgrade confusion
750,000 on the servo thread tmax leaves sufficient margin you reckon? That was only on a very short test mind.
I'm running up to 8ms and 16ms on (turn-key) machines at work, 2ms still sounds pretty good
Time to create page: 0.501 seconds
