Mint 19.2 update
- billykid
- Thank you received: 83
12 Sep 2020 13:27 #181908
by billykid
Mint 19.2 update was created by billykid
After a long time I have updated mint 19.2 plasmac. I have set up the BeagleBrainz repositories and updated but lcnc no longer starts.
I am attaching the error file if you can help me.
Thanks in advance
Mauro
Thanks in advance
Mauro
- snowgoer540
- Thank you received: 907
12 Sep 2020 13:30 #181909
by snowgoer540
Replied by snowgoer540 on topic Mint 19.2 update
Can you post your <machine_name>.ini, <machine_name>.hal, <machine_name>_connections.hal files please?After a long time I have updated mint 19.2 plasmac. I have set up the BeagleBrainz repositories and updated but lcnc no longer starts.
Thanks in advance
Mauro
- billykid
12 Sep 2020 13:43 - 12 Sep 2020 13:46 #181910
by billykid
Replied by billykid on topic Mint 19.2 update
here they are
With these files everything worked before updating .. but I have an ssd copy
Last edit: 12 Sep 2020 13:46 by billykid.
- BeagleBrainz
- Visitor
12 Sep 2020 13:49 #181911
by BeagleBrainz
Replied by BeagleBrainz on topic Mint 19.2 update
That isn't the most recent version in my repo.
When did you setup the repos ?
Have you updated the key from the keyserver as that has changed.
All the ~pre1 packages are no longer in the repo, only the 2.8.0 release is there.
LINUXCNCVERSION: 2.8.0
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un linuxcnc <none> <none> (no description available)
ii linuxcnc-build-deps 1:2.8.0~pre1.6143.gcea561bf1 all build-dependencies for linuxcnc
un linuxcnc-dev <none> <none> (no description available)
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-en 1:2.8.0 all motion controller for CNC machines and robots (English documentation)
un linuxcnc-sim <none> <none> (no description available)
un linuxcnc-sim-dev <none> <none> (no description available)
ii linuxcnc-uspace 1:2.8.0 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.8.0 amd64 PC based motion controller for real-time LinuxWhen did you setup the repos ?
- billykid
12 Sep 2020 14:55 - 12 Sep 2020 15:02 #181922
by billykid
I used these .. I'll try again tomorrow calmly.
strange that it gives an error like i386 but it is 64 bit
Import the key:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys C9F836336AAD909E
Add the source:
sudo add-apt-repository 'deb cnc.beaglebrainz.net/mintcnc/ bionic 2.8-rtpreempt'
Import the key:
Add the source:
Last edit: 12 Sep 2020 15:02 by billykid.
- BeagleBrainz
- Visitor
12 Sep 2020 17:37 #181942
by BeagleBrainz
The packages on my repo are all 64 bit.
Aptget update will mention that there are no 32 bit packages
The repo is good for 64 bit, I test it to make sure it works.
- billykid
13 Sep 2020 01:25 #181981
by billykid
Weird because my system looks like 64-bit.
here are my data.
thanks for your interest
here are my data.
- BeagleBrainz
- Visitor
13 Sep 2020 01:37 #181982
by BeagleBrainz
If this is the messageAll that it is saying is that the repo doesn't support i386 and as you are on a 64 bit system, as that is what the kernel is, it is not an issue.
So you are good to update. I did it on my main machine last night.
N: Skipping acquire of configured file '2.8-rtpreempt/binary-i386/Packages' as repository 'http://cnc.beaglebrainz.net/mintcnc bionic InRelease' doesn't support architecture 'i386'So you are good to update. I did it on my main machine last night.
- phillc54
- Thank you received: 2100
13 Sep 2020 01:37 #181983
by phillc54
Replied by phillc54 on topic Mint 19.2 update
This Unicode error from Axis may point to a translation error:
It may be worthwhile asking on the Users List:
sourceforge.net/projects/emc/lists/emc-users
File "/usr/bin/axis", line 3571, in <module>
print _("\nNote:\nIndividual axis homing is not currently supported for")
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe8' in position 40: ordinal not in range(128)It may be worthwhile asking on the Users List:
The following user(s) said Thank You: billykid, BeagleBrainz
- billykid
13 Sep 2020 02:34 #181984
by billykid
i did it soon .. i put us language and it works fine. maybe then I'll try to solve but it's not too important.
thanks to you
thanks to you
Time to create page: 0.572 seconds
