Mint 19.2 update
- billykid
- Thank you received: 83
15 Sep 2020 13:50 #182256
by billykid
Replied by billykid on topic Mint 19.2 update
I confirm the same problem also with Italian language. i solved it by updating mint from menu to 19.3 tricia the language was still english and everything worked fine. a little while ago I read Robert's post and I went to plasma to do the test in Italian and I saw that it continues to work well.
- BeagleBrainz
- Visitor
15 Sep 2020 13:52 #182257
by BeagleBrainz
Replied by BeagleBrainz on topic Mint 19.2 update
Ok I think that any discussion of Mint 20 should be removed from this thread.
The Mint 20 install is a mixture of Mint & Debian packages that are self installed, where as the packages I have setup are exclusively built on a Mint system.
- RoberCNC
- Thank you received: 25
15 Sep 2020 13:56 #182258
by RoberCNC
Where would BeagleBrainz be appropriate?
Replied by RoberCNC on topic Mint 19.2 update
- BeagleBrainz
- Visitor
15 Sep 2020 14:07 - 15 Sep 2020 14:11 #182259
by BeagleBrainz
That would be for the mods to decide, I was just making a suggestion.
Do you realise on your Mint 20 setups you are using an older kernel than what is on the Linuxcnc Mint 19.x ISOs ?
I’m not having a go at Tommy, but I get a little giggle.
Last edit: 15 Sep 2020 14:11 by BeagleBrainz.
- RoberCNC
15 Sep 2020 14:23 - 15 Sep 2020 14:27 #182261
by RoberCNC
No, I didn't know, I thought that the kernel had to be that, I don't know what the latest operating kernel is for LinuxCNC, I just tried the guide as a curiosity and the other day I came across this thread.
I thought that the contribution would be of some help and I wanted to contribute, there is little more I can do for the community: silly:
Last edit: 15 Sep 2020 14:27 by RoberCNC.
- BeagleBrainz
- Visitor
15 Sep 2020 15:30 #182266
by BeagleBrainz
The problem with mixing the Debian packages on Mint system is there are some slight issues.
You will have an issue if you install the linuxcnc-dev-package which frustrate you if you have a custom user space component.
If later on you wish to have a go at building a run in place version, aka RIP, you will have issues.
I found this out myself and I think another user may have mentioned it as well.
The thing is if you use the same packages from the Ubuntu Bionic repo, the version that Mint 19.x uses, Mint 20 uses Focal, and the Linuxcnc packages from the repo I have setup, you will have a more homogeneous system.
The reason is due the slight differences in versions between the Debian & Ubuntu packages.
- RoberCNC
15 Sep 2020 15:44 - 15 Sep 2020 16:26 #182269
by RoberCNC
Understood, so it can be suicide to migrate a working machine configuration from Debian to Mint, it is not something as simple as copying all the files and paste.
Last edit: 15 Sep 2020 16:26 by RoberCNC.
- BeagleBrainz
- Visitor
15 Sep 2020 18:36 #182301
by BeagleBrainz
Config files for Linuxcnc aren’t the issue.
It’s mixing the software packages of Debian & Ubuntu/Mint that can cause issues or minor surprises.
- billykid
16 Sep 2020 08:25 #182436
by billykid
quite right
I have several small SSDs and have made a habit of making exact copies of the working machine. then I do all the tests I want.
Time to create page: 0.211 seconds
