Mint 19.2 update
- billykid
- Thank you received: 83
13 Sep 2020 11:35 - 13 Sep 2020 15:27 #182020
by billykid
Replied by billykid on topic Mint 19.2 update
Now the simulator works but the 7i80 doesn't work anymore ...
not okay the kernel?
edit
i did some tests now the hm2_eth module loads correctly and shows the pins, but lcnc crashes with this error: trouble looking for handler in plasmac_run.hal
edit
Last edit: 13 Sep 2020 15:27 by billykid. Reason: add linuxcnc.report
- BeagleBrainz
- Visitor
13 Sep 2020 15:43 - 13 Sep 2020 15:51 #182037
by BeagleBrainz
Replied by BeagleBrainz on topic Mint 19.2 update
Kernel is good.
I use Mint myself.
I would not have released the ISO if there were any major issues like that.
Are you sure you copied ALL the files from your original config directory ?
I use Mint myself.
Last edit: 13 Sep 2020 15:51 by BeagleBrainz.
- billykid
13 Sep 2020 16:09 #182038
by billykid
In fact I had missed "postgui.hal". now it works but has some problem with gladevcp because conversational returns errors ... but I'll try again calmly.
thank you
thank you
- Thank you received: 7506
13 Sep 2020 16:12 #182039
Replied by tommylight on topic Mint 19.2 update
Compress your config folder and attach it here, please.
- billykid
13 Sep 2020 16:41 #182040
by billykid
Thanks Tom, first check if I made some big mistake then if anything place the files.
I'm a donkey because I should take more care in copying configuration files
then the memory is what it is
- RoberCNC
- Thank you received: 25
15 Sep 2020 02:45 - 15 Sep 2020 05:25 #182190
by RoberCNC
Replied by RoberCNC on topic Mint 19.2 update
I don't know if it's the right place but since it's closely related ...
Exactly the same error occurs to me. The other day I installed LinuxCNC on Mint 20 following the steps of tommylight (great job Tommy!) All correct. After doing a very basic MILL configuration with PnCConf when starting I get the UnicodeEncodeError. If I change the system language to US it disappears, originally it was all in Spanish. Attached report, I hope it helps the community, thank you.
Is there a way to fix that error without having to change the language?
On the other hand, also add that I found the Hostmot2 firmware problem, "not found", I know that the partport is obsolete, but some of the mortals is what we started with and we have to settle for the moment: P
My Mesa boards are a 5i25 + 7i76.
Last edit: 15 Sep 2020 05:25 by RoberCNC.
- Thank you received: 4660
15 Sep 2020 07:06 #182219
Which language are you using?
This is probably a problem in the .po file.
Replied by andypugh on topic Mint 19.2 update
This Unicode error from Axis may point to a translation error:
print _("\nNote:\nIndividual axis homing is not currently supported for") UnicodeEncodeError: 'ascii' codec can't encode character u'\xe8' in position 40: ordinal not in range(128)
- phillc54
- Thank you received: 2100
15 Sep 2020 07:14 #182221
by phillc54
Replied by phillc54 on topic Mint 19.2 update
The OP didn't mention which language, he was using Mint19.2. The second user was using Spanish on Mint20.
I don't know whether it may be a Mint thing.
In both cases they switched to US and it worked.
15 Sep 2020 07:18 #182223
Yes, but it is a bug if Spanish does not work.
But I don't see anything obviously wrong in es.po:
github.com/LinuxCNC/linuxcnc/blob/2.8/src/po/es.po#L7501
Unless that capital L is the problem? (and isn't actually an L)
- RoberCNC
15 Sep 2020 08:31 #182232
by RoberCNC
Do you need more information or to do more tests?
Do not hesitate to tell me, I will be happy to collaborate with whatever is in my hand.
Time to create page: 0.474 seconds
