- Thank you received: 4153
phillc54 wrote: Camera only.
Rotation is manual with a mouse, right button + scroll.
phillc54 wrote: Good question, I used it with a cheap'n'nasty "endoscope" usb camera I had lying around, similar to this
It also worked on a virtual machine with the inbuilt camera on my Mac.
Another method is to find an edge down the back of the sheet, press a button, and then go to the origin corner and click touchoff and calculate the angle using some trig and adjust for the offset. That is much more accurate when a full sheet (say 2400mm x 1200mm or 3000mm x 1500mm) is used. I have done some work on that with my laser pointer extending some work by BigJohnT.
There's project for you, Qtvcp uses opencv so it's half done.But with the camera, you should be able to implement edge detection and corner detection using opencv features. Imagine that! Just click one button "Align sheet" and let the machine do it all automagically. Let the camera wander around looking for edges then finally move to the origin corner.
phillc54 wrote: There's project for you, Qtvcp uses opencv so it's half done.
Mike_Eitel wrote: Rodw
It's fun.
Tried when was 40'ish. No successful
But i did it!
Happy about.
Mike
