Torch doesn’t move when voltage changes
  • Aldenflorio
  • Aldenflorio's Avatar Topic Author
  • Platinum Member
  • Platinum Member
22 Sep 2020 04:51 #183248 by Aldenflorio
Torch doesn’t move when voltage changes was created by Aldenflorio
I finally got my machine up and running. Everything is working good, though I still need to do some fine tuning. The only issue I can’t sort out myself is this.
I have plasmac set up and I’m using the proma 150 thc. But the torch doesn’t react in the change of voltage. I figured that I just had to adjust the tolerance, but I can’t find anywhere where it lets me configure the thc tolerance
22 Sep 2020 05:07 #183250 by rodw
Have you enabled the THC checkbox?
  • Aldenflorio
  • Platinum Member
  • Platinum Member
22 Sep 2020 05:17 - 22 Sep 2020 05:18 #183253 by Aldenflorio
Replied by Aldenflorio on topic Torch doesn’t move when voltage changes
Yes. I’m using the Titanium plasma 45 plasma cutter from harbor. But it’s on 120, so maybe the that’s contributing to the issue?
Last edit: 22 Sep 2020 05:18 by Aldenflorio.
22 Sep 2020 08:04 #183259 by tommylight
Replied by tommylight on topic Torch doesn’t move when voltage changes
While cutting, check the right side of the LED's
- THC enabled should be ON
- THC UP DN should go on and off as requested from Proma 150
- THC velocity lock should be OFF
- THC void lock should be OFF
  • Aldenflorio
  • Platinum Member
  • Platinum Member
22 Sep 2020 14:31 #183306 by Aldenflorio
I don’t have void lock, and I don’t have velocity lock. I have velocity anti probe
22 Sep 2020 14:32 #183308 by tommylight
  • Aldenflorio
  • Platinum Member
  • Platinum Member
22 Sep 2020 14:35 #183309 by Aldenflorio
In the “run” Tab there’s THC, under THC I have the disable enable and air buttons. Then I have “Velocity Anti dive”. I have no clue what it does.
I’m reading the manual of the proma 150 and it might be something I have to set on the device itself
22 Sep 2020 14:38 #183311 by tommylight
On the Proma set the lowest values possible.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
22 Sep 2020 14:41 - 22 Sep 2020 15:12 #183312 by Aldenflorio
Lowest voltage set point? Or one of the other settings?
I just found this: www.forum.linuxcnc.org/49-basic-configur...etup-issues?start=10
If this is still relevant I can use this
Last edit: 22 Sep 2020 15:12 by Aldenflorio.
22 Sep 2020 15:47 #183316 by tommylight
Time to create page: 0.279 seconds
