Torch doesn’t move when voltage changes
- Aldenflorio
- Thank you received: 15
22 Sep 2020 15:55 #183318
by Aldenflorio
Replied by Aldenflorio on topic Torch doesn’t move when voltage changes
Yup that’s what I found. Thank you
- Aldenflorio
22 Sep 2020 18:10 - 22 Sep 2020 18:26 #183329
by Aldenflorio
Never mind it’s working
Last edit: 22 Sep 2020 18:26 by Aldenflorio.
- Aldenflorio
25 Sep 2020 03:53 #183668
by Aldenflorio
I have an issue. The THC is doing its job, but it’s doing it’s job maybe a bit too well. It’s going up and down like crazy for no reason. well there a reason and I think it’s because it moves too fast going up so the voltage drops so it goes down then the voltage goes up because it’s going too fast for it’s own good.
Now to problem gets solved when I lower the percent of max velocity the thc has. But then I get the problem becomes this: the thc is too slow and it doesn’t move quick enough instead it just hits the metal that’s curved up.
Now I was testing the thc on a drastically curved piece of metal, one that’s unrealistic in the field but I wanted it to be able to do it just because, I didn’t foresee this issue. So should I just accept that the kind of bend isn’t going to happen or is there a way to make the thc be able to adapt quickly without causing the problem?
- phillc54
- Thank you received: 2100
25 Sep 2020 03:58 #183669
by phillc54
Replied by phillc54 on topic Torch doesn’t move when voltage changes
So what value was THC% when it was too fast and what value was THC% when it was too slow?
- Aldenflorio
25 Sep 2020 04:00 - 25 Sep 2020 04:00 #183671
by Aldenflorio
It’s too fast anything above %30. And it’s too slow at 30%. Even at 30% it’s constantly moving up and down. But it’s not as drastic. It’s moving up and down on flat metal btw
Last edit: 25 Sep 2020 04:00 by Aldenflorio.
- phillc54
25 Sep 2020 04:06 #183672
by phillc54
If it is moving up and down while flat then I think you need to fine tune your Proma settings
- Aldenflorio
25 Sep 2020 04:10 - 25 Sep 2020 04:11 #183673
by Aldenflorio
I agree. But I don’t really understand what they do exactly.
There are three settings, other then voltage, to alter
Hysteresis, delay time, and high voltage. Their explanations either have nothing to do with my issue or I don’t understand them. Or both.
cncdrive.com/downloads/CompactTHC_manual.pdf
Last edit: 25 Sep 2020 04:11 by Aldenflorio.
- phillc54
25 Sep 2020 04:14 #183674
by phillc54
Hysteresis would be the amount of voltage variation from the set voltage, so if your set voltage was 100 and the hysteresis was 2 then the range would be from 99V to 101V
- Aldenflorio
25 Sep 2020 04:16 #183675
by Aldenflorio
Ok, so if I mad it 4 then it would wait until 98 and 102 to move up and down respectively if the voltage was set to 100?
- phillc54
25 Sep 2020 04:16 #183676
by phillc54
I think that is how they work, I have never seen one.
Time to create page: 0.209 seconds
