Torch doesn’t move when voltage changes
- Aldenflorio
- Thank you received: 15
22 Sep 2020 04:51 #183248
by Aldenflorio
Torch doesn’t move when voltage changes was created by Aldenflorio
I finally got my machine up and running. Everything is working good, though I still need to do some fine tuning. The only issue I can’t sort out myself is this.
I have plasmac set up and I’m using the proma 150 thc. But the torch doesn’t react in the change of voltage. I figured that I just had to adjust the tolerance, but I can’t find anywhere where it lets me configure the thc tolerance
- Thank you received: 4149
22 Sep 2020 05:07 #183250
Replied by rodw on topic Torch doesn’t move when voltage changes
Have you enabled the THC checkbox?
- Aldenflorio
22 Sep 2020 05:17 - 22 Sep 2020 05:18 #183253
by Aldenflorio
Replied by Aldenflorio on topic Torch doesn’t move when voltage changes
Yes. I’m using the Titanium plasma 45 plasma cutter from harbor. But it’s on 120, so maybe the that’s contributing to the issue?
Last edit: 22 Sep 2020 05:18 by Aldenflorio.
- Thank you received: 7471
22 Sep 2020 08:04 #183259
Replied by tommylight on topic Torch doesn’t move when voltage changes
While cutting, check the right side of the LED's
- THC enabled should be ON
- THC UP DN should go on and off as requested from Proma 150
- THC velocity lock should be OFF
- THC void lock should be OFF
- Aldenflorio
22 Sep 2020 14:31 #183306
by Aldenflorio
I don’t have void lock, and I don’t have velocity lock. I have velocity anti probe
22 Sep 2020 14:32 #183308
?????I have velocity anti probe
- Aldenflorio
22 Sep 2020 14:35 #183309
by Aldenflorio
In the “run” Tab there’s THC, under THC I have the disable enable and air buttons. Then I have “Velocity Anti dive”. I have no clue what it does.
I’m reading the manual of the proma 150 and it might be something I have to set on the device itself
22 Sep 2020 14:38 #183311
On the Proma set the lowest values possible.
- Aldenflorio
22 Sep 2020 14:41 - 22 Sep 2020 15:12 #183312
by Aldenflorio
Lowest voltage set point? Or one of the other settings?
I just found this: www.forum.linuxcnc.org/49-basic-configur...etup-issues?start=10
If this is still relevant I can use this
Last edit: 22 Sep 2020 15:12 by Aldenflorio.
22 Sep 2020 15:47 #183316
