Torch doesn’t move when voltage changes
  • Aldenflorio
  • Aldenflorio's Avatar Topic Author
  • Platinum Member
  • Platinum Member
25 Sep 2020 04:17 #183677 by Aldenflorio
Replied by Aldenflorio on topic Torch doesn’t move when voltage changes
Thank you. I’ll mess with it tomorrow and tell you how it goes.
  • Moderator
  • Moderator
25 Sep 2020 08:30 #183693 by tommylight
Replied by tommylight on topic Torch doesn’t move when voltage changes
Set Proma as low as possible for hyst and delay.
In PlasmaC lower the pid value form 10 to 6 or 7, not the speed.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
25 Sep 2020 12:39 #183712 by Aldenflorio
I don’t have pid. I configured plasmac on mode two. Should I have used a different mode?
Again I have the proma 150 compact thc, not the proma sd
  • Moderator
  • Moderator
25 Sep 2020 13:28 #183716 by tommylight
Sorry, my bad.
THC speed, should be 6 or 7 for normal use with Proma.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
25 Sep 2020 13:42 #183718 by Aldenflorio
6 or 7 percent of the max velocity of the z axis?
  • Moderator
  • Moderator
25 Sep 2020 14:52 #183728 by tommylight
THC speed on the PlasmaC config tab.
Did you set the Proma as mentioned twice above ?
  • Aldenflorio
  • Platinum Member
  • Platinum Member
25 Sep 2020 14:58 #183732 by Aldenflorio
I followed your guide from the link we both had. Except for the second step “ voltage difference at 2” bc I don’t have voltage difference anywhere
  • Moderator
  • Moderator
25 Sep 2020 15:50 #183739 by tommylight
That is the "hys" on the Proma.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
25 Sep 2020 15:52 #183740 by Aldenflorio
Ok. So then it’s followed
Time to create page: 0.103 seconds
