Hypertherm board pinout for RS485 extension board
6 years 1 week ago #186705 by radek_marko
Aha! I was planning to connect serial ports to my Windows laptop, not to LinuxCNC!
I do not know if USB converters will be recognized in Linux.
6 years 1 week ago #186708 by snowgoer540
radek_marko wrote: Aha! I was planning to connect serial ports to my Windows laptop, not to LinuxCNC!
Maybe I've gotten lost in the thread... but what exactly are you trying to achieve?
6 years 1 week ago #186742 by radek_marko
OK, just returned from the workshop and I couldn't get any communication on J11 (expected RS232)
Connection tested using serial params 19200,8,EVEN,1, I've tried several ModBus ASCII apps, even sending a single command as per serial reference doc - no response from the plasma unit.
I think the issue might be in "ENABLE SIGNAL". I've tried to leave it not connected, supply 3.3V to it or connect it to the ground - no joy.
Are there are any proud owners of RS485 board here who have any electronic knowledge and are willing to check how this signal is connected on the original board?
Initially, I was expecting that data available over ModBus / serial link might be sufficient to make PlasmaC act as THC (e.g. by reading arc voltage and adjusting torch hight). That was clarified by Tommylight as a not appropriate approach.
Looking on the pinout make me curious and check if signals on connector J11 on the mainboard are RS232 (3.3V TTL to be more specific) and if those signals can be used for ModBus coms without the original extension board.
6 years 1 week ago #186744 by rodw
Have you reviewed the Hypertherm protocol document (attached)?
Only a very small set of commands are supported.
6 years 1 week ago #186747 by radek_marko
Yes, I did -
I've tried commands from the manual - e.g. ":01062093000145" for setting the cutting mode and few more.
6 years 1 week ago #186750 by rodw
I''m wondering if the enable pin is not meant to be tied to CTS or RTS (or tied to both)
Normally CTS would be connected to the opposite side RTS and vice versa
Time to create page: 0.390 seconds
