Probe testing issues
- phillc54
- Thank you received: 2100
16 Nov 2020 23:48 #189561
by phillc54
Replied by phillc54 on topic Probe testing issues
Yes, jogging Z+ should increase the DRO and Z should move up.
- kramerda
- Thank you received: 14
17 Nov 2020 00:07 #189562
by kramerda
Replied by kramerda on topic Probe testing issues
Reply after trying with reversed Z
I just tried with reversed Z direction so Z Jog+ is travel- now it won't Home because it move away (down) from its home (fully up position). I double checked Z home/limit switch (at top of travel) and Z Max limit (at bottom of travel ) via Hal Watch and they are OK.
- phillc54
17 Nov 2020 00:23 #189564
by phillc54
You may need to set the scale to negative and the search velocity and latch velocity to positive
- kramerda
17 Nov 2020 00:39 #189565
by kramerda
Hi Phil - thanks for hanging in there with me on this one.
Will investigate and try as you suggest -
Is there something unique or wrong with my setup that would require those type of changes. This machine is basically the same as an earlier one I built but switched over to an Rpi4. I'll go back and check the older machines ini and hal because I'm quite curious and still learning but don't think I've run across negative scale and positive search and latch velocities before.
- phillc54
17 Nov 2020 00:46 #189566
by phillc54
That can be just because the motors or drivers are wired differently.
For an example these are my settings:
Warning: Spoiler!
JOINT_0
STEP_SCALE = 41.666666667
HOME_SEARCH_VEL = -30.0
HOME_LATCH_VEL = 1.0
HOME_FINAL_VEL = 15.0
JOINT_1 and JOINT_2
STEP_SCALE = 41.666667
HOME_SEARCH_VEL = 30.0
HOME_LATCH_VEL = -1.0
JOINT_3
STEP_SCALE = -500.0
HOME_FINAL_VEL = 15.0Please Log in or Create an account to join the conversation.
- kramerda
17 Nov 2020 01:00 #189568
by kramerda
thanks, will report back
manana, zzzzzzzzzzzzzzzzzzzzzz
- kramerda
17 Nov 2020 14:51 #189595
by kramerda
Good morning Phil - we're back at it. Using the example you gave and reversing a few signs on my _vel etc. we're getting close.
Can you share your Home, Home Offset, Min and Max Limits for Joint 3 (Z axis).
Mine is working but my down travel is only a few mm.
Also - what variable allows for a little more movement off the home switch following a home sequence.?
Thanks,
Dennis
Thanks,
Dennis
- Clive S
- Thank you received: 486
17 Nov 2020 15:21 #189597
by Clive S
TYPE = LINEAR
HOME = 5.0 This should be -ve then it will come away from the switch
STEP_SCALE = 800.0 Changing the sign will reverse the direction
MIN_LIMIT = -1.0 These next two might have to be reversed
MAX_LIMIT = 50.0
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = -3.333333 Changing the sign will reverse the direction
HOME_LATCH_VEL = -0.500000 Changing the sign will reverse the direction
HOME_FINAL_VEL = 0.000000 this would be the speed it moves to home
Replied by Clive S on topic Probe testing issues
Thanks,
Dennis
TYPE = LINEAR
MAX_LIMIT = 50.0
The following user(s) said Thank You: kramerda
- kramerda
17 Nov 2020 16:22 #189601
by kramerda
Thanks Clive, Phil, and others
Homing is good. Probe test is good. Life is good.
Getting my head around the Z axis where + is towards HOME where my other Axis/Joints X and Y is the opposite, was the big issue.
Also there were some parameters added to Linuxcnc since I first loaded 2.8 a month or so ago and these were left hanging during the PlasmaC config a week ago.
Thanks again,
Dennis
Thanks again,
Dennis
- Clive S
17 Nov 2020 17:35 #189602
by Clive S
Does that mean the Z axis is working OK i.e. jogging down going -ve if so
