Arc OK intermitent issues on torch fire
5 years 10 months ago #192925 by luftlupus
tommylight wrote: Both measurements on both the pictures are correct, the results are also correct, the only thing missing is when you say "attempt a cut" was it actually cutting something, preferably over 3mm thick?
If that was the case, the reading on the first picture should have gone from whatever it was to nearly 0.
To more accurately check that, do as Phill asked, disconnect the ARCOK wires, be it at the plasma or from the mesa board, use the same diode/buzzer check between those two wires and start cutting something, it should start buzzing and go to near 0.
If it does not, reverse the wires and try again.
Post pictures or values from both measurements.
So the arc does not actually fire anymore you can hear it trying in the background. But here is a short video of testing the transfer pins like you said.
5 years 10 months ago #192935 by phillc54
I see that earlier you said the maximum current for the transfer was 50mA. The relay manufacturer specs it at 1A. Is there a fuse in the circuit somewhere?
5 years 10 months ago #192936 by luftlupus
phillc54 wrote: I see that earlier you said the maximum current for the transfer was 50mA. The relay manufacturer specs it at 1A. Is there a fuse in the circuit somewhere?
Not on the transfer it just goes to the relay and back out.
5 years 10 months ago #192938 by phillc54
Bummer.
So where is it at now, are you getting an arc?
5 years 10 months ago #192941 by luftlupus
phillc54 wrote: Bummer.
na no pilot arc or anything i am assuming the relay is gone at this stage. it tries to fire but no arc of course just air.
5 years 10 months ago #192942 by phillc54
Aha, so no need to worry about the transfer side yet.
Disconnect the plasma machine cnc port from the controller and short out pins 3 & 4, that should turn the torch on.
The following user(s) said Thank You: snowgoer540, luftlupus
