Arc OK intermitent issues on torch fire
5 years 10 months ago #192779 by rodw
So this appears to be the 5V relay docs
4donline.ihs.com/images/VipMasterIC/IC/P...02568146F3353EA87419
It appears to be 1 amp at 30 volt DC so the 90 Ohm resistor ( 2 x 270 Ohm) will give 267 mA @ 24 Volt so its still within spec.
The following user(s) said Thank You: luftlupus
5 years 10 months ago #192780 by luftlupus
rodw wrote: So this appears to be the 5V relay docs
So 2 of these would do the job?
I checked for traces and connectivity but neither connect them together.
5 years 10 months ago - 5 years 10 months ago #192781 by phillc54
luftlupus wrote: So this is the relay at the end of the transfer pins but it seems a lot smaller from what i was expecting to find.
If that is the transfer relay then you shouldn't need any contact wetting. The minimum switching current for it is 10uA at 10mV.
Last edit: 5 years 10 months ago by phillc54.
5 years 10 months ago #192782 by rodw
My mistake, you need three!
5 years 10 months ago #192783 by luftlupus
Would using one cause an issue? or just not be enough for the desired effect?
5 years 10 months ago #192785 by luftlupus
only following through with this as i had swapped my one 1k 1watt resistor for one of the 270ohm 5 watt. because the manufacturer was vague so i didn't want to overload the relay with all 3 at once. But on that note was cutting great with the new 1 resistor until this afternoon when i can only assume something has let the magic smoke go as when the torch tries to fire now there is no pilot arc or ArkOK signal coming back to the GUI. so maybe i have blown the transfer relay i am thinking.
Time to create page: 0.168 seconds
