Arc OK intermitent issues on torch fire
5 years 10 months ago #191625 by phillc54
It is looking more and more like an issue in the machine then. :(
Do they use a mechanical relay?
5 years 10 months ago #191626 by luftlupus
phillc54 wrote: It is looking more and more like an issue in the machine then. :(
From what i got back from them yes its a dry contact mechanical relay.
5 years 10 months ago #191627 by phillc54
OK, if not I was going to suggest swapping 12 and 14 to reverse the current direction in the machine.
Seeing as you have checked all the wiring and connectors, I have run out of ideas...
5 years 10 months ago #191628 by luftlupus
phillc54 wrote: OK, if not I was going to suggest swapping 12 and 14 to reverse the current direction in the machine.
might try that anyway cant trust what they say half the time. If not i might do a dodgy and pick up a new machine from a tool shop hook it up and see if i am having the same issue or not, then return the machine.. lol
Then just send mine off for repair or whatever they want to do.
5 years 10 months ago #191629 by tommylight
Again, lower the pierce height.
Try 3 or 2.5mm, see if that happens again.
If the torch is high it can not reach the threshold to activate the arcok signal, although the arc is established and cutting.
Or raise the cutting current a bit if possible.
The following user(s) said Thank You: luftlupus
5 years 10 months ago #191633 by luftlupus
tommylight wrote: Again, lower the pierce height.
Ill try that.
Time to create page: 0.392 seconds
