- Thank you received: 16
snowgoer540 wrote:
luftlupus wrote: Also got word back that its a dry contact.
Your arc ok is a dry contact relay inside the plasma cutter, yes.
I’m saying some machines are sensitive to using a solid state switch to control “torch on”.
This would not work for me, I had to change the torch on to a dry contact mechanical relay. In my case, it’s specifically what Hypertherm calls for. When I get to work I’ll link a video (if I still have one) of what my torch used to do. It’s exactly like your first video.
rodw wrote: I've said this before but no one listened... but its such a simple solution.
I would use the timedelay component and connect the torch on signal to that. Set the delay for about 0.2 seconds
Use timedelay.N.out for your ArcOK.
See: linuxcnc.org/docs/2.8/html/man/man9/timedelay.9.html
that would be great cheers.
PlasmaC can already do this natively. It's probably not the appropriate solution to this gentleman's problem though.
linuxcnc.org/docs/devel/html/plasma/plas...html#_lost_arc_delay
The aforementioned feature was added 1 month ago. He IS getting a valid arc ok at least for a few mS, or he wouldn't get the "valid arc-ok lost". The new (1 month ago) feature allows a user to set a pin with a time period for PlasmaC to force the arc-ok true AFTER it loses the signal, without interruption. Which is essentially what you're proposing. Otherwise, to bypass the arc ok completely, without your free solution, he could just click "ignore arc-ok".rodw wrote: Plasmac has some native handling but what I propose is bypassing Plasmac and always enforcing Arc OK.
The RAZOR CUT 45 (what OP has) is a "low frequency pilot arc" plasma cutter.I think as has been reported in the past that Plasmac gets confused with HF induced voltage fluctuations.
Not sure I "poo poo"'d anything? I guess I missed the voltage plots? Or was that just irrelevant rambling/chest pounding? Either way, it doesn't mean my experiences have no merit.Please don't poo poo considered advice from someone who has been playing with plasma cutting for several years before Plasmac was even conceived and has studied thousands of voltage plots.
Perhaps, but it caused me a very similar issue, and changing it to what the manual calls for fixed it.I personally think your concerns about the spindle relay are unfounded. There are a number of users following that approach and I've been using an optocoupled relay for the last two years to trigger my torch without any issues.
