- Thank you received: 2100
with only around 8hours cut time i wouldn't think i would have oxidization build up on this connection. i can only think bad relay internally.phillc54 wrote: That will give you around 24mA which would "probably" be adequate.
phillc54 wrote: Lots of variable in play, humidity etc.
Is that previous schematic how you are currently connected.
