tommylight wrote: I feel sorry for the OP.....
Update PlasmaC to at least version 0.182
Use a hardware ARCOK if possible
Software ARCOK works properly, it is just trickier to set up.
If torch on is working, leave it as is. To test it, use the MESH/Ignore ArcOK feature in PlasmaC and cut something while watching the ARCOK input on halshow or halmeter.
B.T.W, there might be cases when an opto can cause issues with starting something. To long ....
snowgoer540 wrote: Also, if I were you, I would debounce the arc-ok input assuming it is a mechanical relay from your plasma cutter. The following changes will give you 5 servo-thread counts of deounce (if your servo-thread period is 1mS, then a 5mS debounce). This may (or may not) save you some headaches later.
Edit your plas_connections.hal file and make the following changes:
Change:To:Code:loadrt debounce cfg=3Code:loadrt debounce cfg=3,1
Add:Code:setp debounce.1.delay 5 addf debounce.1 servo-thread
Change:To:Code:net plasmac:arc-ok-in hm2_5i25.0.7i76.0.0.input-10 => plasmac.arc-ok-inCode:net plasmac:arc-ok-in hm2_5i25.0.7i76.0.0.input-10 => debounce.1.0.in net plasmac:debounced-arc-ok debounce.1.0.out => plasmac.arc-ok-in
So i added this to the hal file
if i wanted to add a bigger delay to the arkOK do you know exactly what i would change?
Also checked the wiring and its solid, I did also just update from v0.144 to v0.185 before making this topic.
