- Thank you received: 907
luftlupus wrote: i was told by PCW to wire it that way on the spinena and someothers do it on different pins also.
ill also check into those settings cheers
Ok, so looking at the MESA manual for the 7i76, it looks to me like he told you to do that because the SPINENAs are spindle isolated outputs for controlling spindle direction... but they are special because they are opto isolated outputs coupled with darlington transistors, capable of switching a 50mA load of 0 to 100VDC.
I definitely had a problem with my plasma cutter doing almost the exact same thing I saw in your first video when I had it wired with a Solid State switching device.
I HAD to go to a mechanical, dry contact relay for the torch-on output for it to work. I would be willing to bet you're having the same problem. My guess is that it wasn't near enough current to bias the transistor, and therefore never completely closed the circuit to get a solid start. My pilot arc would be puny sometimes, and sometimes there would be none, sometimes it worked fine. I would get arc-ok lost errors, basically everything you've described.
Switch to a dry contact relay, and use a regular output. I would posit that the problem goes away.
rodw wrote: Using the spindle relay is OK on a 7i76. Thats how PCW suggested and it saves an output but I must confess, I never rewired mine from the output I started with after I read his advice.
luftlupus wrote: Also got word back that its a dry contact.
