Suggestion QtPlasma and PlasmaC
- crowloy
- Thank you received: 19
03 Mar 2021 22:45 #200951
by crowloy
Suggestion QtPlasma and PlasmaC was created by crowloy
I use a program called lightburn for my CO2/diode lasers. One feature that I use alot is the frame button. This basically runs the nozzle around what you are cutting in a square to make sure you have room on the material to cut that particular item. I noticed linuxcnc has a extents display on screen giving the location of the start as well as the length/width. I know I missed this feature as I was cutting some items and missed the plate on the one
- snowgoer540
- Thank you received: 895
03 Mar 2021 23:39 #200956
by snowgoer540
Replied by snowgoer540 on topic Suggestion QtPlasma and PlasmaC
Interesting. Normally I just look at the preview window and jog the torch around the extents of the program's movements (white/grey lines) and then jog the torch down at each critical point and make sure it will have enough material to eat.
Seems to work well. Though it's not automated like you're saying.
Take this for example, the yellow is my jog path prior to running the program:
- Thank you received: 7460
04 Mar 2021 00:30 #200970
Replied by tommylight on topic Suggestion QtPlasma and PlasmaC
Pretty sure this was discussed here before, but my google-foo if failing me !
Also pretty sure there was some kind of solution, most probably python checking the extents in the gcode file and generating the test pattern.
- phillc54
- Thank you received: 2100
04 Mar 2021 00:34 #200971
by phillc54
Replied by phillc54 on topic Suggestion QtPlasma and PlasmaC
I have seen that request before but forgot about it...
So there is no Z motion, just a rapid to X/Y start point then X/Y motion in a rectangle around extents at current material speed?
- snowgoer540
04 Mar 2021 00:54 #200973
by snowgoer540
I dont want to speak for OP, but it might be useful to just do it at cut height?
Maybe just treat it like a dry run, but instead of dry running the gcode, it just dry runs a rectangle around the program extents?
04 Mar 2021 01:28 #200974
For what is worth, i have 5 Euro (very expensive, i know) "cross" laser pointers on all new machines, makes life much easier.
I would not, it will bump the torch to the material, very bad material here.......but it might be useful to just do it at cut height?
- snowgoer540
04 Mar 2021 01:54 #200976
by snowgoer540
How do you do a dry run then?
I think I might get one of those lasers soon. Phill has a pretty nifty touchoff tool now that's native to QtPlasmaC. Seems pretty useful.
- Thank you received: 2173
04 Mar 2021 01:58 #200977
Replied by cmorley on topic Suggestion QtPlasma and PlasmaC
- phillc54
04 Mar 2021 02:01 #200978
by phillc54
Thanks Chris, that is helpfull, I didn't know about that...I wonder if the 'gcode properties' info is useful for that - you could use the info to build a macro to rapid around the perimeter...
04 Mar 2021 09:14 #201005
I just watch the laser while jogging manually, leaving the torch up.
Time to create page: 0.175 seconds
