Suggestion QtPlasma and PlasmaC
10 Mar 2021 18:44 #201679 by Uthayne
Replied by Uthayne on topic Suggestion QtPlasma and PlasmaC
Good call, for some reason I never thought to do that. I usually jog it around manually.
10 Mar 2021 19:04 #201686 by tommylight
Replied by tommylight on topic Suggestion QtPlasma and PlasmaC
Thinking of it, the rectangle thingy will not work for plasma as the torch will be high enough for us mortals not to be able to see it line up properly with the material, has something to do with perception .... My torches are 150mm above the material ! :pinch:
10 Mar 2021 19:12 #201688 by snowgoer540
Replied by snowgoer540 on topic Suggestion QtPlasma and PlasmaC
No worries Tommy, Snowy's got your back... haha I had the same use case as I don't have a laser either, so all you have to do is add "usecurrentZheight" in the INI file to run the framing routine at the current Z height :)
From linuxcnc.org/docs/devel/html/plasma/qtpl...ml#qt_button-framing:
...it is possible for the user to omit the initial Z movement and run the framing sequence at the current Z height by adding "usecurrentZheight" after "framing".
BUTTON_n_CODE = framing usecurrentZheight
10 Mar 2021 20:50 #201708 by tommylight
But i do have lasers, it's just that ... well i can not see them 3 meters away from me ! :)
10 Mar 2021 20:56 #201711 by snowgoer540
I’ll mail you some metric binoculars in that case. :)
10 Mar 2021 22:00 #201730 by phillc54
Replied by phillc54 on topic Suggestion QtPlasma and PlasmaC
QtPlasmaC has a fairly good run from line option:
linuxcnc.org/docs/devel/html/plasma/qtpl...tml#qt_run-from-line
Time to create page: 0.297 seconds
