QTPlasmaC Crashing bug report
05 Apr 2021 02:16 #204848 by Nick7251
Replied by Nick7251 on topic QTPlasmaC Crashing bug report
Do you have a Torch Pulse button set in the .ini file as a user button?
Yes. Torch pulse doesn't cause any errors.
05 Apr 2021 02:19 #204849 by phillc54
Replied by phillc54 on topic QTPlasmaC Crashing bug report
I wasn't suggesting that it was, the error you posted suggests that it cannot find a Torch Pulse button.
Could you post your ini file.
05 Apr 2021 02:39 #204850 by phillc54
I can emulate that error here, I have pushed a fix for it.
It is from not having a Torch Pulse button or maybe the code for the TP button in the ini file is not quite correct.
It should be something like:
BUTTON_n_CODE = torch-pulse 0.5
05 Apr 2021 03:01 #204852 by Nick7251
Looks like I was wrong. I did have torch pulse enabled, but I must have turned it back off at some point.
So this problem is because it is looking torch pulse to be enabled?
05 Apr 2021 03:05 #204854 by phillc54
No, the code had a bug that assumed the Torch Pulse button was existing even if it wasn't.
If you put the correct torch pulse code in your ini file that will fix it for you until LinuxCNC is updated.
05 Apr 2021 03:09 #204855 by Nick7251
Yes indeed. I just put the torch pulse back in the ini file, and I now get a pause as expected when the arc is lost instead of the software throwing an error, and closing. Thanks for helping me with that. Looking forward to the update.
Time to create page: 0.107 seconds
