Torch will not Fire
5 years 5 months ago #209045 by rodw
Replied by rodw on topic Torch will not Fire
phillc54 wrote:
rodw wrote: I think the torch is trying to be turned on and is then turned off by Plasmac for some reason.
If that were the case then it should give a lost arc error. Apparently there are no error messages.
Strange, if air starts to flow the torch had to be triggered.
If disabling arc OK does not work, I think its time to look at arc ok, torch on and torch voltage in halscope when the torch attempts to start.
5 years 5 months ago #209047 by rodw
When I look back, I don't think using the hand torch confirms the machine torch is OK but it does confirm the inverter is OK. PLease review Tommy's post too.
5 years 5 months ago #209048 by phillc54
Replied by phillc54 on topic Torch will not Fire
+1
5 years 5 months ago - 5 years 5 months ago #209050 by rodw
phillc54 wrote:
+1
If there was an issue in the torch, the parts in place error would not allow air flow.
The only other possible issue is poor connection on the high voltage side. Torch connections, ground clamp etc. But in my experience, Plasmac would report a fault as you state.
Manually short the relevant torch on pins (1&2 from an earlier thread) to see if it fires.
Last edit: 5 years 5 months ago by rodw.
5 years 5 months ago #209079 by tommylight
Replied by tommylight on topic Torch will not Fire
Press F9 on the keyboard, wait for at least 60 seconds, press F9 again.
Report exactly what is happening.
5 years 5 months ago - 5 years 5 months ago #209098 by bevins
Replied by bevins on topic Torch will not Fire
tommylight wrote: Press F9 on the keyboard, wait for at least 60 seconds, press F9 again.
What is it with you and F9?
WTF does F9 do?
/EDIT AH! I found it....
Last edit: 5 years 5 months ago by bevins.
