[QTvcp.QTVCP.QT_PSTAT][INFO] No qss file found (qt_pstat.py:152)
[QTvcp.QTVCP.QT_PSTAT][INFO] No qrc file found (qt_pstat.py:176)
[QTvcp.QTVCP.QT_PSTAT][INFO] No resources.py file found, No QRC file to compile one from. (qt_pstat.py:197)
[QTvcp][INFO] Building A Linuxcnc Main Screen with Python 2 (qtvcp:136)
[QTvcp][INFO] No handler file specified on command line (qtvcp:154)
[QTvcp][INFO] No HAL component base name specified on command line using: qtplasmac (qtvcp:185)
[QTvcp.QTVCP.WIDGETS.CAMVIEW_WIDGET][ERROR] Qtvcp Error with camview - is python3-opencv installed? (camview_widget.py:47)
[QTvcp.QTVCP.QT_MAKEGUI][INFO] No resource file to load: None (qt_makegui.py:186)
<commandline>:0: Pin 'ini.z.max_limit' does not exist
<commandline>:0: Pin 'ini.z.min_limit' does not exist
[QTvcp][INFO] postgui filename: ['custom_postgui.hal'] (qtvcp:361)
[QTvcp][INFO] Preference path:
