QTPlasmaC mode2 - valid arc lost
  • fernandosf
  • fernandosf's Avatar Topic Author
  • Senior Member
  • Senior Member
12 Sep 2021 11:15 - 12 Sep 2021 11:16 #220338 by fernandosf
Replied by fernandosf on topic QTPlasmaC mode2 - valid arc lost
I have eliminated the line with "torch-off-probe".
Oddly, QTPC is not reading my config values (in custom.hal) for "db_arc-ok.delay" and "plasmac.arc-lost-delay" :
Last edit: 12 Sep 2021 11:16 by fernandosf.
  • fernandosf
  • Senior Member
  • Senior Member
12 Sep 2021 12:53 #220345 by fernandosf
I have noticed something strange.
When IHS occurs and torch is fired,
my external THC is set to wait for a delay of 1.5s before sending UP/DOWN to B.O.B.
As seen in the video below, in the right/down corner, THC DOWN is ON the moment the ARCOK is ON. And Z is diving until it hits the material. The problem is the external THC is NOT sending DOWN at that moment (I checked visually, don't have 2 cameras to record both QTPC and external THC).
I guess that when it hits the material, the plasma source extinguishes the ARC (my guess) and THC Arc OK is GONE from the external THC.
Any clues?
  • fernandosf
  • Senior Member
  • Senior Member
12 Sep 2021 13:03 - 12 Sep 2021 13:03 #220346 by fernandosf
I have just confirmed with a multi-meter that external THC is not sending DOWN signal while THC DOWN Light (on QTPC) is ON.
My external THC is fed by a notebook source at 19V (specs are from 12 to 24v).
The DOWN input from B.O.B. (or DOWN output from external THC) reads 10V when not activated and 200mV when active.
The same happens with external THC UP / ArcOK outputs.
Last edit: 12 Sep 2021 13:03 by fernandosf.
  • Moderator
  • Moderator
12 Sep 2021 14:05 #220359 by tommylight
Replied by tommylight on topic QTPlasmaC mode2 - valid arc lost
-Disable THC in LinuxCNC
-Try to cut something
-Fix the other THC first till it can reliably cut while the THC in LinuxCNC is disabled.
The following user(s) said Thank You: fernandosf
  • fernandosf
  • Senior Member
  • Senior Member
15 Sep 2021 09:51 #220701 by fernandosf
By "Disable THC in LinuxCNC" you mean the button at QTPlasmaC interface?
Should I keep all the wiring between external THC and BOB ?
I've found an old topic you give lots of tips, will extract everything I can from that
  • Moderator
  • Moderator
15 Sep 2021 11:18 #220715 by tommylight
Yes and yes.
  • fernandosf
  • Senior Member
  • Senior Member
17 Sep 2021 11:10 #220919 by fernandosf
Thanks tommylight, I have followed your advices and things are becoming clearer now.
My THC Arc-ok closes the Chinese BOB input when the sensor is active (it goes down to 0 Volts), I thought it would translate into a TRUE when the sensor is active but it is quite the opposite.
So I have inverted all the UP, DOWN, Arc-ok inputs and it's looking good at the QTPC GUI. Next I'll try with the Plasma Source On.
I think QTPC THC docs could have an more through approach like it was done with "Homing" (it was a breeze to learn that).
I'm not complaining, you guys are awesome, thanks.
17 Sep 2021 12:32 #220927 by snowgoer540
Replied by snowgoer540 on topic QTPlasmaC mode2 - valid arc lost
Happy to consider all suggestions/feedback to make the learning curve easier for new users. That said, could you be more specific as to which section, etc. you'd like to see improved, and perhaps how?
  • Moderator
  • Moderator
17 Sep 2021 13:01 #220934 by tommylight
LOL @ Bart ! :)
  • fernandosf
  • Senior Member
  • Senior Member
17 Sep 2021 13:11 - 17 Sep 2021 13:14 #220938 by fernandosf
I would go section by section and make notes about improvements, not sure where you host that (github?), but that would be a work apart.
The general idea I'm talking about is that PlasmaC documentation is very complete, few things missing if any, the problem is that some complex topics (like THC) deserve a more didactic approach. Things like:
- illustrations and images instead of text only;
- real life examples;
- explanation (or pointers) to related concepts and pre-reqs;
- what can go wrong on most common mistakes;
Anyway, I see the docs improved a lot overtime, and I see it is slowly getting more like a book than a dictionary. I hope I can contribute with that as soon as I leave the noob arena.
Last edit: 17 Sep 2021 13:14 by fernandosf.
The following user(s) said Thank You: phillc54, tommylight, snowgoer540, Pirocobb
Time to create page: 0.472 seconds
