Cutting issue
- UncleRemus
18 Sep 2021 22:08 #221065
by UncleRemus
Cutting issue was created by UncleRemus
First off thanks to all those who built and maintain this project.
I am running mint 19.2 with QTPlasmac..It cuts all files perfect, other then having to hit resume on each new "cut".
My problem is when running gcode my torch goes to the first pierce point, does it thing
(touches off fires, cuts,, turns off , raises and moves to next pierce point).
Here it touches off rises to fire height, pauses a sec. and returns home.
As soon as it reaches home i can click resume and it lowers and does it thing.
Next piece point same thing.
Its like it "pauses" on every cut cycle inside the gcode.
Any ideas on where i need to poke around to fix this? It's not a huge issue just annoying to have to hit the resume button all the time.
Would my air not cycling off during this cause this? By the time it has returned home the air has cycled off.
- phillc54
- Thank you received: 2100
19 Sep 2021 00:05 #221067
by phillc54
Replied by phillc54 on topic Cutting issue
Are you geting any popup error/warning messages? If not then your Linux distros may not be showing these. Next time it pauses check in the Parameters Tab (or Settings Tab for a 4x3 GUI) and see if there is a message in the machine log. The machine log was added in QtPlasmaC V1.0.39 so you would need that version or later.
- UncleRemus
19 Sep 2021 02:16 #221069
by UncleRemus
Replied by UncleRemus on topic Cutting issue
No messages. Will check the machine log tomorrow (if i have one). Thanks
- phillc54
19 Sep 2021 02:19 - 19 Sep 2021 02:19 #221070
by phillc54
You will get a new log each time you restart the machine, the five previous logs are kept in the config directory and are plain text files.
Last edit: 19 Sep 2021 02:19 by phillc54.
- UncleRemus
19 Sep 2021 10:12 #221097
by UncleRemus
running QtPlasmaC 1.0.32 so no machine logs. Guess its upgrade time. Now i wonder how to do that.
- UncleRemus
19 Sep 2021 10:31 - 19 Sep 2021 12:17 #221100
by UncleRemus
So it appears i am running Linuxcnc v2.9.0-pre0-3879 which is a stretch build. My current QtPlasmaC is v1.0.32. My link says i am running the most current version but the repo hasnt been updated since 05/21. So i am lost on how to up it.
Edit: Can i upgrade from stretch to buster so i can get the latest release? I have mint 19.2 as my o/s and like it so really dont want to screw up the connection between linuxcnc and mint.
Last edit: 19 Sep 2021 12:17 by UncleRemus.
- snowgoer540
- Thank you received: 907
19 Sep 2021 12:37 #221123
by snowgoer540
Replied by snowgoer540 on topic Cutting issue
You should be able to just edit the "distribution" field in the repositories section of the synaptic package manager from "stretch" to "buster". Then update as normal.
- UncleRemus
19 Sep 2021 15:07 #221145
by UncleRemus
seen your distro of MX Linux snowgoer. The older i get the more i like simple, so i may give it a go. Looks fairly painless. Then just load by backup configs.
- snowgoer540
19 Sep 2021 16:58 #221153
by snowgoer540
If you decide to give it a go, let me know if you run into any issues, it should be fairly pain free though. Any feedback is welcome.
I really like MX Linux, it feels light, and snappy.
- UncleRemus
19 Sep 2021 20:18 - 20 Sep 2021 11:26 #221168
by UncleRemus
Well i got MX Linux with Linuxcnc installed. Went pretty smooth, I had to use EPS? instead of MBR for my boot. Other then that no issues. Great instructions!
It was getting late havnt tried to run it yet, will fire it up tomorrow.
Edit: So it all works other then my old configs. Havnt quite figured out how to import them. Might just copy them over by hand to the new working set of configs.The new ones are in a different format then my old ones.
Last edit: 20 Sep 2021 11:26 by UncleRemus.
