Cutting issue
20 Sep 2021 11:55 #221209 by snowgoer540
Replied by snowgoer540 on topic Cutting issue
There should be a section in the docs I put up there about restoring a previously-working config.  It's as easy as extracting the backup file, and copying the right folder to your new config folder, or creating it if it does not exist.
You also have to create the a new symbolic link, but that's covered in the doc too.
Alternatively, you could just re-run pncconf and use all of your previous settings which will create you a new folder, config, links, etc.
20 Sep 2021 12:36 #221210 by UncleRemus
Replied by UncleRemus on topic Cutting issue
Yeah i have tried twice, the docs are very detailed, two thumbs up on the work put into it.
I am just going to re-run pcconf and fill with my previous config. No biggie.
I am sure my issue is user related, as everything else in the guide was spot-on.
20 Sep 2021 12:37 #221212 by snowgoer540
What doesnt work exactly?
20 Sep 2021 13:45 #221216 by UncleRemus
Actually 3rd time was a charm...Cleared out the config folder, deleted the launcher, my backup and started over fresh from that point and it all went smooth. Maybe my backup caught a glitch while unzipping or my fat fingers hit a wrong key, no idea....
Now to see if my original issue fixed itself or not.
Thanks for the distro and the docs!
20 Sep 2021 14:32 #221224 by snowgoer540
You’re welcome, glad to hear you got it going. Fingers crossed..
22 Sep 2021 10:54 #221351 by UncleRemus
Ok so i now have an error "valid arc lost", but i ticked the "ignore ok" box and it seems to work fine now or at least it finished running this gcode fine.
22 Sep 2021 13:42 #221361 by snowgoer540
When do you get the error?
If it is in the beginning of the cut, try increasing the arc_ok debounce delay in the custom.hal file from 5mS to 10mS.
If it is at the end of the cut, you could set the lost arc delay by adding this code to your custom.hal file (which would set it to 0.1s):
setp plasmac.arc-lost-delay 0.1
Reference for the lost arc delay in case you want it:
linuxcnc.org/docs/devel/html/plasma/qtpl...html#_lost_arc_delay
22 Sep 2021 13:44 #221362 by snowgoer540
Of course, I should mention that the above assumes your piece height has been calibrated using probe test, and you're using the appropriate pierce height, cut height, feed rate, amperage, gas pressure, etc...
22 Sep 2021 20:23 - 22 Sep 2021 20:33 #221388 by UncleRemus
First cut piece everything is perfect, moves to 2nd piece +, it will touch off rise to fire height pause a second & return home ( this is where i get the error).
Will add some arc_ok debounce to it and see.
Last edit: 22 Sep 2021 20:33 by UncleRemus.
22 Sep 2021 20:35 #221389 by phillc54
Replied by phillc54 on topic Cutting issue
Can you post the gcode file that exhibits this issue.
Time to create page: 0.098 seconds
