Cutting issue
- UncleRemus
23 Sep 2021 21:59 #221479
by UncleRemus
Replied by UncleRemus on topic Cutting issue
What i dont understand is that on the first pierce and any pierce afterwards (as long as i hit resume) the arc_ok is fine.
I can live with the ignore_ok box checked, but THC would be nice.
Yeah i need to dial back the lead-in/outs....trying to eliminate a divot and went too far.
- snowgoer540
- Thank you received: 907
23 Sep 2021 22:01 #221480
by snowgoer540
Replied by snowgoer540 on topic Cutting issue
It probably wouldn’t hurt for you to post a backup of your configuration made from the settings or parameters tab.
- phillc54
- Thank you received: 2100
23 Sep 2021 22:26 #221482
by phillc54
Insert a line like this:before the second one of these lines:
linuxcnc.org/docs/devel/html/gcode/g-code.html#gcode:g4
Maybe start off with a high value to begin with say 3 seconds or so
Another thing to check is that the gas pressure hasn't dropped too much from the previous cut.
Replied by phillc54 on topic Cutting issue
Maybe your machine cannot restart so quickly after a cut. It may be worth trying a delay in between a couple of the cuts to see if that helps.What i dont understand is that on the first pierce and any pierce afterwards (as long as i hit resume) the arc_ok is fine.
G4 P0.5M3 $0 S1 (plasma start)linuxcnc.org/docs/devel/html/gcode/g-code.html#gcode:g4
- Thank you received: 7505
24 Sep 2021 06:04 #221490
Replied by tommylight on topic Cutting issue
Video would probably help...
- UncleRemus
24 Sep 2021 13:02 #221513
by UncleRemus
It's fixed ( i think ). Has run two full gcodes with zero errors.
Thanks everyone for the help!
Not exactly sure what fixed it yet.
Will have to go back and change some things back one by one until it starts throwing an error again.
