Cutting issue
23 Sep 2021 05:20 #221418 by snowgoer540
Replied by snowgoer540 on topic Cutting issue
I'm also curious what kind of plasma cutter you are using?
23 Sep 2021 10:20 #221435 by UncleRemus
Replied by UncleRemus on topic Cutting issue
Can you post the gcode file that exhibits this issue.
Here is two, they all do it.....Using sheetcam and the latest PP posted by Les in here.
23 Sep 2021 10:22 #221436 by UncleRemus
It's a Prime Cut 60
23 Sep 2021 10:28 - 23 Sep 2021 10:29 #221437 by snowgoer540
Has increasing the arc_ok delay helped?
The fact that ignoring the Arc Ok causes it to work is telling.  It tells me that there's something going on with that circuit, be it with "bounce" noise in the software, or with the physical circuit.
If increasing the arc_ok delay does not help, there is a section in the docs about contact load, which may help you as well.
Edit:  linuxcnc.org/docs/devel/html/plasma/qtpl...html#qt-contact-load
Last edit: 23 Sep 2021 10:29 by snowgoer540.
23 Sep 2021 17:58 #221453 by UncleRemus
arc_ok delay did not solve it.....same thing first pierce perfect, second pierce error & pause.
WIll check out the docs....it works fine with ignore ok checked, but from what i read this also disables my THC?
23 Sep 2021 18:09 #221455 by phillc54
Replied by phillc54 on topic Cutting issue
Is there any difference if you change the "pe" value to 0.0
(o=0, ph=0.12, pd=0.2, ch=0.06, fr=100, th=1, cv=99, pe=0.2, jh=0, jd=0)
To:
(o=0, ph=0.12, pd=0.2, ch=0.06, fr=100, th=1, cv=99, pe=0.0, jh=0, jd=0)
23 Sep 2021 18:34 - 23 Sep 2021 18:36 #221460 by UncleRemus
To:
[code](o=0, ph=0.12, pd=0.2, ch=0.06, fr=100, th=1, cv=99, pe=0.0, jh=0, jd=0)
[/code]
Where would i do this?
Last edit: 23 Sep 2021 18:36 by UncleRemus.
23 Sep 2021 18:37 #221462 by phillc54
[/code]
To:
Where would i do this at?
Edit the gcode file, it is around 20 lines from the top.
23 Sep 2021 18:53 #221467 by snowgoer540
One other thing that I see is that you are using really long lead ins and lead outs.  The lead outs especially will be a problem because they require cutting over either something that was almost certainly already cut, or a bit of material that will have dropped out.  For the gorilla file, a lot of the lead ins and lead outs get really close to a cut line for another part.  And there are some lead ins and lead outs that overlap each other.
23 Sep 2021 19:50 #221477 by UncleRemus
Changed the gcode and still the same.
