Qtplasmac Framing velocity
  • paulsao
  • paulsao's Avatar Topic Author
  • Elite Member
  • Elite Member
18 Oct 2021 09:38 #223458 by paulsao
Qtplasmac Framing velocity was created by paulsao
I am using Qtplasmac and in the Framing function according to the user guide to set the speed I put an F1000 code for example at the end of the button but actually when testing it is always taking the cutting speed of the material, someone else experiences that or I am getting lost Of something?
18 Oct 2021 10:04 #223462 by snowgoer540
Replied by snowgoer540 on topic Qtplasmac Framing velocity
When we added it (back in August), it did work.
What version of QtPlasmaC are you on (it's in the header of the window)?
Can you post the exact button code you are using?
  • paulsao
  • Elite Member
  • Elite Member
18 Oct 2021 10:08 - 18 Oct 2021 10:09 #223463 by paulsao
Replied by paulsao on topic Qtplasmac Framing velocity
Qtplasmac v1. 0.32 The code is as follows: BUTTON_9_CODE = framing usecurrentzheight F2000
Last edit: 18 Oct 2021 10:09 by paulsao.
  • paulsao
  • Elite Member
  • Elite Member
18 Oct 2021 10:14 #223465 by paulsao
It is a question of the version, you are absolutely right, thank you.
18 Oct 2021 10:16 #223466 by snowgoer540
Ah, that's the issue.  The functionality you are referencing was added in v1.0.76 on 2021 Aug 28.
The user guide always assumes the user is on the latest version of QtPlasmaC.
The following user(s) said Thank You: paulsao
  • paulsao
  • Elite Member
  • Elite Member
18 Oct 2021 10:39 #223467 by paulsao
I did the update with apt update as indicated but I do not get the update, did a migration from Plasmac to qtplasmac do I have to use the qtplasmac-qtplasmac2qt option again for it to update or why is it not updated?
18 Oct 2021 10:45 #223468 by snowgoer540
I am guessing you are on Stretch, or have your repositories pointed toward the Stretch sources. If you give me more info about what distribution of Linux you are on, maybe I can help point you in the right direction...
  • paulsao
  • Elite Member
  • Elite Member
18 Oct 2021 10:59 #223469 by paulsao
Thanks, I am using debian 10 linux 2.9 and in the attached image my repository. It's weird because Plasmac updated the same way and it worked.
18 Oct 2021 11:10 - 18 Oct 2021 11:32 #223470 by snowgoer540
The distribution is pointed to Stretch.  It needs to be set to "Buster" for both the deb and deb-src.  Then it will update.  You will have to uninstall Linuxcnc before doing that and reinstall it afterward.  It should not affect your config.
The last supported version on Stretch was the version you are currently on.
Last edit: 18 Oct 2021 11:32 by snowgoer540. Reason: missed the y in your
  • paulsao
  • Elite Member
  • Elite Member
18 Oct 2021 12:12 #223478 by paulsao
I have some packages that are not installed, for installation over some missing dependencias.
Time to create page: 0.186 seconds
