Qtplasmac Framing velocity
- snowgoer540
- Thank you received: 907
19 Oct 2021 12:40 #223580
by snowgoer540
Replied by snowgoer540 on topic Qtplasmac Framing velocity
Glad you got it going.
Enjoy the Framing moves at specific Feed rate
The following user(s) said Thank You: paulsao
- Thank you received: 4155
19 Oct 2021 13:10 #223585
Replied by rodw on topic Qtplasmac Framing velocity
WIndows NTFS partitions might know how to handle symlinks but FAT and FAT32 partitions (eg USB thumb drives) do not.
The last time I moved to a new fresh installation, I used gparted to format a thumb drive to EXT4 and copied file via it. That also solved the problem.
So by untarring your archive that started life on an EXT4 partition back onto an EXT4 partition your symlinks were preserved.
Time to create page: 0.124 seconds
