QtPlasmaC update problem
24 Oct 2021 23:35 #224147 by CFE
QtPlasmaC update problem was created by CFE
Hi all,
I have noticed that our QtPlasmaC is still on version v1.0.32 (Buildbot installation), although I have just last week and again this morning run "sudo update" and "sudo upgrade". Does anybody have clue why this is ?
24 Oct 2021 23:43 #224148 by phillc54
Replied by phillc54 on topic QtPlasmaC update problem
Are your apt sources pointing to "stretch" rather than "buster"
24 Oct 2021 23:46 #224149 by CFE
Replied by CFE on topic QtPlasmaC update problem
Hi Phil, the repositories are set to stretch. Cheers, Peter
25 Oct 2021 00:00 #224151 by phillc54
Then you will need to change them to buster, stretch has not been building master since around May.
25 Oct 2021 00:21 #224153 by CFE
Hi Phil, does that also mean I have to change the debian source to buster ? I run stretch at the moment.
25 Oct 2021 00:26 #224154 by phillc54
If you open a terminal in stretch and enter python3 what version does it return?
25 Oct 2021 00:43 #224155 by CFE
Hi Phil,
I get this from python3 :
plasma@Plasma:~$ python3
Python 3.5.3 (default, Sep 27 2018, 17:25:39)
[GCC 6.3.0 20170516] on linux
25 Oct 2021 00:50 #224157 by phillc54
Buster has python3.7, so your options at the moments are:
Stay on Stretch with an older version of QtPlasmaC and wait until the python versions are sorted.
Move to the Buster distribution.
25 Oct 2021 01:04 #224161 by CFE
Hi Phil,
I have upgraded to Buster, I suppose buildbot will upgrade LinuxCNC overnight before we see a version change ?
25 Oct 2021 01:10 #224163 by phillc54
The latest QtPlasmaC on bulildbot isĀ 1.215.107 which is from yesterday.
Did you change the sources in Synaptic?
Time to create page: 0.502 seconds
