QTvcp copy Error
3 years 4 months ago #273305 by Samas322
QTvcp copy Error was created by Samas322
Hi I just tried to copy the QTplasmaC GUI to modify it but as soon as i copy it in the machine directory (by using "qtvcp copy" in the terminal, and before i attempt any modification) QtplasmaC wont launch and send me this error. i tried it with a clean installation also and still not work. i also try the same thing with qtdragon but this time it worked. it seams to be an error in qtplasmac_handler.py but im not sure. can anyone help me please?
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl: Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/lib/tcltk/linuxcnc/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.6 LINUXCNC - 2.10.0-pre0-1498-g9dbb4192c Machine configuration directory is '/home/ssm/linuxcnc/configs/sim.qtplasmac' Machine configuration file is 'qtplasmac_l_imperial.ini.expanded' INIFILE=/home/ssm/linuxcnc/configs/sim.qtplasmac/qtplasmac_l_imperial.ini.expanded VERSION=1.1 PARAMETER_FILE=imperial_parameters.txt TPMOD= HOMEMOD= TASK=milltask HALUI=halui DISPLAY=qtvcp qtplasmac COORDINATES=XYYZ KINEMATICS=trivkins coordinates=xyyz Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Starting HAL User Interface program: halui linuxcnc TPMOD=tpmod HOMEMOD=homemod EMCMOT=motmod twopass:invoked with <> options twopass:found ./sim_no_stepgen.tcl twopass:found /usr/share/linuxcnc/hallib/qtplasmac_comp.hal twopass:found ./custom.hal Starting TASK program: milltask Starting DISPLAY program: qtvcp Shutting down and cleaning up LinuxCNC... task: 943 cycles, min=0.000009, max=0.010113, avg=0.009788, 0 latency excursions (> 10x expected cycle time of 0.010000s) identityKinematicsSetup: coordinates:xyyz    Joint 0 ==> Axis X    Joint 1 ==> Axis Y    Joint 2 ==> Axis Y    Joint 3 ==> Axis Z identityKinematicsSetup: Recommend: kinstype=both Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: Note: Using POSIX realtime [QTvcp.QTVCP.QT_MAKEGUI][[31mERROR[0m]  Trouble looking for handlers in 'qtplasmac_handler': (qt_makegui.py:333) Traceback (most recent call last):   File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 311, in _load_handlers     objlist = h(halcomp, widgets, self.PATHS)  # this sets the handler class signature   File "/home/ssm/linuxcnc/configs/sim.qtplasmac/qtplasmac/qtplasmac_handler.py", line 6051, in get_handlers     return [HandlerClass(halcomp, widgets, paths)]   File "/home/ssm/linuxcnc/configs/sim.qtplasmac/qtplasmac/qtplasmac_handler.py", line 145, in __init__     self.update_check()   File "/home/ssm/linuxcnc/configs/sim.qtplasmac/qtplasmac/qtplasmac_handler.py", line 2390, in update_check     os.rmdir(os.path.join(self.PATHS.CONFIGPATH, 'qtplasmac')) OSError: [Errno 39] Directory not empty: '/home/ssm/linuxcnc/configs/sim.qtplasmac/qtplasmac' [QTvcp][[41mCRITICAL[0m]  Aborted from Error Dialog  Qtvcp encountered an error.  The following information may be useful in troubleshooting: LinuxCNC Version  : 2.10.0-pre0-1498-g9dbb4192c Traceback (most recent call last):   File "/usr/bin/qtvcp", line 518, in <module>     _qtvcp = QTVCP()   File "/usr/bin/qtvcp", line 261, in __init__     window.load_extension(opts.usermod)   File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 268, in load_extension     methods, self[obj].handler_module, self[obj].handler_instance = self._load_handlers([handlerpath], self.halcomp, self[obj])   File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 311, in _load_handlers     objlist = h(halcomp, widgets, self.PATHS)  # this sets the handler class signature   File "/home/ssm/linuxcnc/configs/sim.qtplasmac/qtplasmac/qtplasmac_handler.py", line 6051, in get_handlers     return [HandlerClass(halcomp, widgets, paths)]   File "/home/ssm/linuxcnc/configs/sim.qtplasmac/qtplasmac/qtplasmac_handler.py", line 145, in __init__     self.update_check()   File "/home/ssm/linuxcnc/configs/sim.qtplasmac/qtplasmac/qtplasmac_handler.py", line 2390, in update_check     os.rmdir(os.path.join(self.PATHS.CONFIGPATH, 'qtplasmac')) OSError: [Errno 39] Directory not empty: '/home/ssm/linuxcnc/configs/sim.qtplasmac/qtplasmac'  (qtvcp:474) 15732 15763 Stopping realtime threads Unloading hal components Note: Using POSIX realtime ----------------------------------------------------------------------- Info report created by linuxcnc_info: The file:    /tmp/linuxcnc_info.txt can be posted to a forum or a web site like:      http://pastebin.com in order to provide information about the linuxcnc system and configuration.                 Date: Sat Jun 10 19:54:38 EDT 2023             UTC Date: Sat Jun 10 23:54:38 UTC 2023         this program: /usr/bin/linuxcnc_info               uptime: 19:54:38 up 2:56, 1 user, load average: 0.77, 0.75, 0.58      lsb_release -sa: Debian Debian GNU/Linux 10 (buster) 10 buster             linuxcnc: /usr/bin/linuxcnc                  pwd: /home/ssm/linuxcnc/configs/sim.qtplasmac                 USER: ssm              LOGNAME: ssm                 HOME: /home/ssm               EDITOR:               VISUAL:             LANGUAGE: en_CA:en                 TERM: dumb            COLORTERM:              DISPLAY: :0.0              DESKTOP: xfce         display size: 1440x900 pixels (381x238 millimeters)                 PATH: /usr/bin:/home/ssm/linuxcnc/configs/sim.qtplasmac/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games uname items:          nodename -n: PlasmaCNC       kernel-name -s: Linux       kernel-vers -v: #1 SMP PREEMPT RT Debian 4.19.282-1 (2023-04-29)           machine -m: x86_64         processor -p: unknown          platform -i: unknown       oper system -o: GNU/Linux /proc items:              cmdline: BOOT_IMAGE=/boot/vmlinuz-4.19.0-24-rt-amd64 root=UUID=e7af7f7a-65e7-48e6-86e4-3ea860bf22ee ro quiet           model name: AMD A10-6700 APU with Radeon(tm) HD Graphics                cores: 2              cpu MHz: 2183.484              parport:               serial: Versions:                  gcc: gcc (Debian 8.3.0-6) 8.3.0               python: Python 3.7.3                  git: not_in_PATH           git commit: NA                  tcl: 8.6                   tk: 8.6                glade: not_in_PATH linuxcnc_var all:      LINUXCNCVERSION: 2.10.0-pre0-1498-g9dbb4192c LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples             REALTIME: /usr/lib/linuxcnc/realtime                  RTS: uspace           HALLIB_DIR: /usr/share/linuxcnc/hallib               PYTHON: /usr/bin/python3 dpkg -l '*linuxcnc*': Desired=Unknown/Install/Remove/Purge/Hold | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad) ||/ Name                   Version                       Architecture Description +++-======================-=============================-============-===================================================================== un  linuxcnc               <none>                        <none>       (no description available) un  linuxcnc-dev           <none>                        <none>       (no description available) un  linuxcnc-doc           <none>                        <none>       (no description available) ii  linuxcnc-doc-en        1:2.10.0~pre0.1498.g9dbb4192c all          motion controller for CNC machines and robots (English documentation) un  linuxcnc-doc-es        <none>                        <none>       (no description available) ii  linuxcnc-doc-fr        1:2.10.0~pre0.1498.g9dbb4192c all          motion controller for CNC machines and robots (French documentation) un  linuxcnc-sim           <none>                        <none>       (no description available) un  linuxcnc-sim-dev       <none>                        <none>       (no description available) ii  linuxcnc-uspace        1:2.10.0~pre0.1498.g9dbb4192c amd64        motion controller for CNC machines and robots ii  linuxcnc-uspace-dbgsym 1:2.10.0~pre0.1498.g9dbb4192c amd64        debug symbols for linuxcnc-uspace ii  linuxcnc-uspace-dev    1:2.10.0~pre0.1498.g9dbb4192c amd64        PC based motion controller for real-time Linux
3 years 4 months ago #273309 by Samas322
Replied by Samas322 on topic QTvcp copy Error
Ok so i removed few spaces in front of the elif just before the "os.rmdir..." around line 2390 and now it seems to work but im not sure if i fixed it or if i bypassed some feature! Anyway it will need to be fixed for future updates.
3 years 4 months ago #273317 by phillc54
Replied by phillc54 on topic QTvcp copy Error
Thanks for the report, we will take a look at it.
3 years 4 months ago - 3 years 4 months ago #273336 by snowgoer540
Replied by snowgoer540 on topic QTvcp copy Error
To help figure out the root cause, and how to address it, can you tell me what's still in the directory?
Last edit: 3 years 4 months ago by snowgoer540.
3 years 4 months ago - 3 years 4 months ago #273342 by Samas322
Its the copy of the gui that i made with "qtvcp copy" for editing it. As i tell you i removed spaces in front of the else before this line and it solved the probleme. I think the else have been moved accidently. This section of code i think is for unlink the original handler.ini file and use the copied one in this directory. For whatever reason it tried to delete this folder.
finaly it is not supposed to delete the folder.
Last edit: 3 years 4 months ago by Samas322.
3 years 4 months ago #273346 by snowgoer540
It IS supposed to delete the folder.  qtplasmac as a symlink, or a directory should not exist inside of a config folder anymore, this is something we used in the past.  You are getting the error because the folder is not empty, which is something I did not expect when I added that line of code.
I am asking what is in that particular folder, as I want to understand this edge case before I change the code to just delete the directory regardless of its contents.
Can you copy and paste the results of the following terminal command:
ls /home/ssm/linuxcnc/configs/sim.qtplasmac/qtplasmac
Time to create page: 0.105 seconds
