QTvcp copy Error
- snowgoer540
- Thank you received: 907
12 Jun 2023 22:44 - 13 Jun 2023 00:30 #273429
by snowgoer540
Replied by snowgoer540 on topic QTvcp copy Error
Interesting. I use cut recovery a lot, but I don’t think I ever press the REV button (with the laser). I’d you press cycle pause, and then just use the directional arrows to use a new touch off point, does it behave differently?
Last edit: 13 Jun 2023 00:30 by snowgoer540.
- Samas322
- Thank you received: 10
13 Jun 2023 01:53 #273436
by Samas322
Replied by Samas322 on topic QTvcp copy Error
I looked at the gcode file and nothing change in it when you do a recovery... it must be an internal code. I searched in the handler file but found nothing revelant so i think there must be a code file somewhere only for the cut recovery? I dont know much about the architecture of linuxcnc but i want to learn! If possible can you let me know if you found something please? Or at least just telling me where to search and maybe i could help you if i found something!
- Samas322
13 Jun 2023 02:00 #273437
by Samas322
Snowgoer540 ok i'll try it tommorow!
- Samas322
13 Jun 2023 20:01 #273507
by Samas322
Alright i just tested what you tell me to do and that worked perfectly well! So its just when im using the laser with the rev button that it happen.
- snowgoer540
13 Jun 2023 20:05 #273508
by snowgoer540
Thank you for doing the testing on that, that really helps narrow down where to look.
To be clear, you had the laser on still, you just didnt use REV, correct?
- Samas322
13 Jun 2023 20:10 #273509
by Samas322
exact! but i did a test also with the laser using rev AND arrow key and it worked well also. so its only when i used the laser with rev but NO arrow key that the bug occur.
- Samas322
13 Jun 2023 20:33 #273513
by Samas322
i tried a lot of different things to reproduce the framing bug but it did not happened. I'll keep an eye on that and if i found anything i will tell you!
- phillc54
- Thank you received: 2100
16 Jun 2023 01:34 #273672
by phillc54
A fix has been pushed for this. Thanks for the report.
Replied by phillc54 on topic QTvcp copy Error
Also i noticed few bugs, when you do cut recovery and align with the laser then restart the cut the torch will probe down normaly then start and made a weird move in z and never start moving in xy. Even with the arc ok.
The following user(s) said Thank You: Samas322
- Samas322
16 Jun 2023 01:48 #273674
by Samas322
Time to create page: 0.261 seconds
