QTvcp copy Error
12 Jun 2023 06:43 #273371 by phillc54
Replied by phillc54 on topic QTvcp copy Error
There is an update on the way to allow keybind changes via a user command file as described here:
linuxcnc.org/docs/devel/html/gui/qtvcp.h...cp:modifying-screens
12 Jun 2023 07:35 #273372 by phillc54
A bit more hacking has revealed that the update isn't required, you should be able to do it from a user command file and not need to copy the handler file.
Sample:
import types
from qtplasmac_handler import KEYBIND as KB
def on_keycall_Any(self, event, state, shift, cntrl):
    s = 'pressed' if state else 'released'
    print(f'space is {s}:\nstate: {state}\nshift: {shift}\ncntrl: {cntrl}\n')
KB.add_call('Key_Any', 'on_keycall_Any')
self.on_keycall_Any = types.MethodType(on_keycall_Any, self)
KB.del_call('Key_R')
  • Samas322
  • Samas322's Avatar Topic Author
  • Junior Member
  • Junior Member
12 Jun 2023 09:30 #273378 by Samas322
Replied by Samas322 on topic QTvcp copy Error
Oh nice! I already tried to make a user command file but wasnt able to load it in qtplasmac by adding USER_COMMAND_FILE = keyboard.py... in the display section of the .ini file. But i was able to create user_periodic.py and this file load perfectly but i tested for adding keyboard shortcuts but it never worked.. probably due to my low level programming skills..  but i will try it with your sample file! The only things im still not sure how to implement in this file is some timers...?
12 Jun 2023 09:44 #273379 by phillc54
You would need to import the timer, something like:
from PyQt5.QtCore import QTimer
The following user(s) said Thank You: Samas322
  • Samas322
  • Junior Member
  • Junior Member
12 Jun 2023 10:21 #273383 by Samas322
Ok good i'll try this this afternoon! Thanks!
  • Samas322
  • Junior Member
  • Junior Member
12 Jun 2023 10:25 - 12 Jun 2023 12:14 #273384 by Samas322
Also i noticed few bugs, when you do cut recovery and align with the laser then restart the cut the torch will probe down normaly then start and made a weird move in z and never start moving in xy. Even with the arc ok.
And some time when you do a framing with the laser the torch wont probe when you hit cycle start after the framing. You need to power off qtplasmac then power on to continue.
Last edit: 12 Jun 2023 12:14 by Samas322.
12 Jun 2023 15:32 #273398 by snowgoer540
Replied by snowgoer540 on topic QTvcp copy Error
Thanks for the bug reports. I've not noticed either of those, but step 1 for squishing bugs is being able to reproduce the, so I will try to reproduce them. Do you find that these happen consistently, or sporadically?
I ask because I've recently used cut recovery and align with the laser, and I didnt have any issues. So if you are getting it consistently can you either make another video, or give the exact steps to reproduce?
Same with the framing. I use framing every time I use my table and I've not run into that one yet.
I may reach out with more questions as I get time to look into it.
  • Samas322
  • Junior Member
  • Junior Member
12 Jun 2023 16:11 #273400 by Samas322
For the cut recovery it append every time for me i will do a video when i get home. For the framing it did not happened consitently. I dont know if i did something different when it happened but i'll try to figure it out.
  • Samas322
  • Junior Member
  • Junior Member
12 Jun 2023 22:18 - 12 Jun 2023 22:21 #273426 by Samas322
The cut recovery bug that i tell you. The bug of framing did not happend but i'll try to replicate it and inform le you as soon as i found something!
Last edit: 12 Jun 2023 22:21 by Samas322.
12 Jun 2023 22:39 #273427 by tommylight
Replied by tommylight on topic QTvcp copy Error
Probably recovery code adding another M3 somewhere?
Time to create page: 0.324 seconds
