- User Interfaces
- Plasmac
- Button erstellt und er soll auch schalten Button created and he should also swit
- phillc54
- Thank you received: 2100
01 Dec 2023 11:28 #286962
by phillc54
Replied by phillc54 on topic Button erstellt und er soll auch schalten Button created and he should also swit
The material overlay text is set in a method in qtplasmac_handler.py named get_overlay_text, you could patch that similar to how power_state is patched in qtplasmac_custom.py and just remove the line if self.pmx485Exists:
The label with 'ON' is created as l1 = QLabel('ON'), you could rename it self.some_name and change wherever l1 appears to the new name. Then the text could be set anywhere with self.some_name.setText('NEW TEXT')
doc.qt.io/qtforpython-5/PySide2/QtWidgets/QLabel.html
- Plasmanfm
- Thank you received: 22
01 Dec 2023 17:48 #286980
by Plasmanfm
Replied by Plasmanfm on topic Button erstellt und er soll auch schalten Button created and he should also swit
Hallo phillc54
I can't handle that, I need an example !!
King regarde and thankˋs
Juergen
Juergen
- phillc54
01 Dec 2023 23:36 #287002
by phillc54
I modified the last custom code that you posted:
The label is named self.pwmgn_label.
I have also added cut amps to the overlay in a more simple way than I described earlier.
All the changes are commented.
- Plasmanfm
02 Dec 2023 18:36 #287042
by Plasmanfm
Hallo phillc54
my heartfelt thanks again
I wouldn't have been able to do that with my limited programming knowledge.
yes, everything works also the highlights ( the on..off , and the cut amps )
king regarde and thank´s
Jürgen
Jürgen
- User Interfaces
- Plasmac
Time to create page: 1.436 seconds
